Having issues with mqtt in a new install. Had it perfectly running on the same machine, Ubuntu 18.04, but got into so many issues with the 0.86.x upgrade so I decided to start over. Now i’m getting an error I can’t figure out. Guessing it’s something simple I forgot.
Running Mosquitto on the same server as HA. Doing a mosquitto_sub
from command line shows incoming messages, even publishing a message from HA GUI works, it shows up in the mosquitto_sub
on the command line. But the log when starting HA shows:
2019-01-30 14:31:34 ERROR (MainThread) [homeassistant.setup] Error handling when_setup callback for mqtt
File "/usr/local/lib/python3.6/dist-packages/homeassistant/setup.py", line 263, in when_setup
await when_setup_cb(hass, component)
File "/usr/local/lib/python3.6/dist-packages/homeassistant/components/owntracks/__init__.py", line 115, in async_connect_mqtt
context.mqtt_topic, async_handle_mqtt_message, 1)
File "/usr/local/lib/python3.6/dist-packages/homeassistant/components/mqtt/__init__.py", line 319, in async_subscribe
qos, encoding)
File "/usr/local/lib/python3.6/dist-packages/homeassistant/components/mqtt/__init__.py", line 696, in async_subscribe
raise HomeAssistantError("Topic needs to be a string!")
homeassistant.exceptions.HomeAssistantError: Topic needs to be a string!
Help is much appreciated
