I am using a sonof Zigbee dongle on MQTT - WORKING FINE
I have updated this to latest firmware running amber
I have downloaded the Add on - Zigbee2MQTT
I have downloaded the HA Integration MQTT
So my problem is that, I can install a Zigbee devise in to the Add on Zigbee2MQTT dashboard and i see the device and all looks good
I have paired a scene controller (infact i have paired 2 to establish that the devise wasn’t faulty)
I click on the devise and hit the expose tab and i can see the buttons are working fine on Both controllers
All seems to be working fine.
I then go to the MQTT HA integration and i can see the device has been brought in to HA
The button presses are now not registering on the Log and it seems like the device its self is not there as a “scene controller” and the only entity i can select is the Battery status.
Hope this make sense but i am stuck…
I have brought in a motion sensor and this works perfect in HA so im confused
You can see in Mqtt2zigbee tab exposure what the device exposes. Not everything will be an entity in HA as some will be treated as events (for example the action of click or double click).
If you want to perform actions based on the events, you need to listen to the topic and figure out the right event.
I have imported a scene controller (4 Button) in to Zigbee2MQTT
All seems to work fine as when i push buttons 1-4 they all are registering within the log
I then go into the MQTT integration on HA and i can see the device.
Logbooks will show changes on entities. As the buttons are not reflected as entities (you don´t see them in your screenshot) they will not be shown there.
I see there is one entity not shown (likely not relevant, but check which one it is).
What do you see in Zigbee2MQTT? This is what I see for example for one of my buttons :
