Hi
I am trying to setup MQTT with my Hisense TV following this guide:
If I use MQTT Explorer on my Windows machine this works fine with the Cert File and Key and I can control the TV.
When I try from Home Assistant with a bridge, it fails to connect:
1624709343: Connecting bridge hisensemqtt (192.168.1.150:36669)
1624709343: Socket error on client local.HomeAssistant, disconnecting.
This is my config:
connection hisensemqtt
address 192.168.1.150:36669
username hisenseservice
password multimqttservice
clientid HomeAssistant
bridge_certfile /ssl/rcm_certchain_pem.cer
bridge_keyfile /ssl/rcm_pem_privkey.pkcs8
bridge_insecure true
bridge_tls_version tlsv1.2
try_private false
start_type automatic
topic +/remoteapp/# both
So because that fails I thought I would try it from the command line.
When I try to run this:
mosquitto_sub -d -h 192.168.1.150 -t "/remoteapp/#" -p 36669 --cert /ssl/rcm_certchain_pem.cer --key /ssl/rcm_pem_privkey.pkcs8 -u hisenseservice -P multimqttservice
It just says “Sending Connect” over and over again with no response.
It is the exact same key and cert I am using on my machine and username / password.
