I’m connecting my generator to my home assistant via MQTT. I have a YAML file based on one published by @gregmac that contains 26 entities. My generator is sending data to my HA and 16 of the 26 entities seem to be working fine. They get data populated as expected. The others do not and I can’t figure out why. I’ve tried all sorts of things to try to fix it, including turning off the JSON numerics, turning on underscores instead of spaces in names, but nothing worked. I could use some help.
Here is my YAML file.
## Package / Generator
# Version 0.5-greg
# Package for Home Assistant. See https://www.home-assistant.io/docs/configuration/packages/
# This interfaces Home Assistant to a Generac generator montiored by
# https://github.com/jgyates/genmon
# Based on version 0.5 of the configuration by Louis Mamakos <[email protected]> at
# https://community.home-assistant.io/t/monitor-your-generac-generator-with-home-assistant/62701
# Modifications:
# - Minor changes for being ESP32-based
# - Use JSON numerics (to avoid string parsing)
# - Add icons, device_class, etc
# Required Genmon MQTT settings:
# - Blacklist Filter: Run Time,Monitor Time,Generator Time,Communication Stats,Platform Stats
# - JSON Numerics: ON
# - Root topic: (blank)
# Notes:
# - unique_id values in this file are not signficant (or
# even required at all). They exist so that the entities show up
# within the Home Assistant configuration GUI for customization.
# - MQTT topics need to match what is configured in genmon
mqtt:
- unique_id: "fd8f8c07-7d6f-4aea-92b5-16b7d8acc66b"
expire_after: 300 # genmon MQTT flushes out MQTT updated every 60 seconds
state_topic: 'generator/Outage/Status'
name: Generator Outage Status
icon: mdi:alarm-light-outline
- unique_id: "f565fed6-8a19-49d4-8066-4015c5ca91b1"
state_topic: 'generator/Outage/Utility_Voltage/value' # if JSON numerics
#state_topic: 'generator/Outage/Utility Voltage' # if JSON numerics
name: Generator Utility Voltage
icon: mdi:sine-wave
device_class: voltage
unit_of_measurement: "V"
# status related sensors
- unique_id: "713eb4b9-feec-4425-8c83-84a9f486aae7"
name: Generator Battery Voltage
icon: mdi:car-battery
state_topic: 'generator/Status/Engine/Battery_Voltage/value'
#state_topic: 'generator/Status/Engine/Battery Voltage'
- unique_id: "83fd4b02-1b5b-4f0c-8a90-fc7cd102a190"
name: Generator Switch State
icon: mdi:electric-switch
state_topic: 'generator/Status/Engine/Switch_State'
- unique_id: "63f6e276-be1d-44ad-8a8a-fe4af30bcff8"
name: Generator Engine State
state_topic: 'generator/Status/Engine/Engine_State'
- unique_id: "f3a8aedd-206b-4e5f-baa9-677496ee8d3c"
icon: mdi:gauge
unit_of_measurement: "RPM"
state_topic: 'generator/Status/Engine/RPM/value' # if JSON numerics
#state_topic: 'generator/Status/Engine/RPM' # if JSON numerics
- unique_id: "cbdc9c28-5748-4aef-91bc-5b5ec95ed545"
name: Generator Frequency
device_class: frequency
unit_of_measurement: "Hz"
state_topic: 'generator/Status/Engine/Frequency/value' # if JSON numerics
#state_topic: 'generator/Status/Engine/Frequency' # if JSON numerics
- unique_id: "f5f462db-e16d-4596-9bd3-232b70fa5038"
name: Generator Output Voltage
state_topic: 'generator/Status/Engine/Output_Voltage/value' # if JSON numerics
#state_topic: 'generator/Status/Engine/Output Voltage' # if JSON numerics
# current measurement is garbage on 22KW product, apparently
- unique_id: "10e1def6-35fd-4922-932a-90f25abb7f29"
name: Generator Output Current
device_class: current
unit_of_measurement: "A"
icon: mdi:sine-wave
state_topic: 'generator/Status/Engine/Output_Current/value' # if JSON numerics
#state_topic: 'generator/Status/Engine/Output Current' # if JSON numerics
# current measurement is garbage on 22KW product, apparently, so this value may
# also be suspect on that model
- unique_id: "914a4e97-54a0-41e7-bbeb-a256134e5e35"
name: Generator Output Power
device_class: power
unit_of_measurement: "W"
state_topic: 'generator/Status/Engine/Output_Power_(Single_Phase)/value' # if JSON numerics
#state_topic: 'generator/Status/Engine/Output Power (Single Phase)' # if JSON numerics
# this is normalized to watts from kilowatts
value_template: '{{ value | float * 1000 | round(0) }}'
- unique_id: "8cb64471-9123-48f6-b9be-15c01595981e"
name: Generator Last Alarm Log
state_topic: 'generator/Status/Last_Log_Entries/Logs/Alarm_Log'
- unique_id: "bce3182a-a525-47dc-937c-8be4e5afc619"
name: Generator Last Service Log
state_topic: 'generator/Status/Last_Log_Entries/Logs/Service_Log'
- unique_id: "faa2f487-fc30-4e9c-8733-5b27270b3e17"
name: Generator Last Run Log
state_topic: 'generator/Status/Last_Log_Entries/Logs/Run_Log'
# maint related sensors
- unique_id: "bf7cbe92-2b1e-48ca-addd-df963697626c"
device_class: power
state_topic: 'generator/Maintenance/Rated_kW'
# normalize to watts
value_template: '{{ value | regex_replace(" *[Kk]W", "") | float * 1000 | round(0) }}'
unit_of_measurement: 'W'
- unique_id: "825657b6-c67a-427a-bee9-7b6ea2182628"
name: Generator Exercise Time
icon: mdi:fan-clock
state_topic: 'generator/Maintenance/Exercise/Exercise_Time'
# might be nice to maybe somehow normalize this, but not sure into what date/time representation
# value is something like: "Weekly Sunday 17:35 Quiet Mode On"
- unique_id: "41c981db-5979-4ee6-b9fb-d1ca44f83b3f"
expire_after: 300
name: Generator Total Run Time
device_class: duration
unit_of_measurement: h
state_topic: 'generator/Maintenance/Service/Total_Run_Hours/value' # if JSON numerics
#state_topic: 'generator/Maintenance/Service/Total Run Hours' # if JSON numerics
value_template: '{{ value | default(0) | float }}'
- unique_id: "927b24b7-772d-434a-8fa1-4f1c5549c90d"
expire_after: 300
name: Generator Hardware Version
state_topic: 'generator/Maintenance/Service/Hardware_Version'
- unique_id: "4cf182de-c37b-48c9-8727-75e1f5053d0d"
expire_after: 300
name: Generator Firmware Version
state_topic: 'generator/Maintenance/Service/Firmware_Version'
- unique_id: "8f9caada-2e90-4cb9-9571-597a27b97a9e"
expire_after: 300
name: Generator Service A Due
state_topic: 'generator/Maintenance/Service/Service_A_Due'
# value is something like "191 hrs or 04/12/2024"
- unique_id: "6ec00786-1eaf-4a58-b97a-57052cc0641c"
expire_after: 300
name: Generator Service B Due
state_topic: 'generator/Maintenance/Service/Service_B_Due'
- unique_id: "7f37ec3c-e1c5-4e10-ba9d-f8f15d27a019"
expire_after: 300
name: Generator Battery Check Due
state_topic: 'generator/Maintenance/Service/Battery_Check_Due'
# value is something like "4/12/2024"
# genmon monitor related sensors
- unique_id: "9bc1d83a-34bc-4a1e-a643-3c0eb62501dd"
expire_after: 300
state_topic: 'generator/Monitor/Generator_Monitor_Stats/Generator_Monitor_Version'
- unique_id: "93029e3e-bc4f-4aa3-b8e0-b0a30aeeaee9"
name: Genmon HAT Temperature
icon: mdi:thermometer
device_class: temperature
state_topic: 'generator/Status/External_Sensors/HAT_Ambient/value'
#state_topic: 'generator/Status/External Sensors/HAT Ambient'
unit_of_measurement: "°F"
- unique_id: "c63a832d-69bb-4502-b60b-9912f82ed1eb"
name: Genmon CPU Temperature
state_topic: 'generator/Monitor/Platform_Stats/CPU_Temperature'
# probably the most useful sensor - are we in a power outage condition or not?
binary_sensor:
- unique_id: "468414df-32b1-4127-8636-4202a11b880c"
name: Generator Power Outage
state_topic: 'generator/Outage/System_In_Outage'
payload_on: 'Yes'
payload_off: 'No'
############################################################################3
# Fun facts (For 22kw generac model)
# Per specification, fuel consumption for propane is
# 2.56 gal/hr at 50% load (11KW)
# 3.87 gal/hr at 100% load (22KW)
# Per genmon code, the 3 term polynomial to compute this is: [0, 2.74, 1.16]
# gal/hr = (T0 * pctLoad^2) + (T1 * pctLoad) + T3
# gal/hr = 2.74 * pctLoad + 1.16
# This is a pretty good fit to the spec sheet -
# 50% = 2.53 gal/hr (vs 2.56 spec)
# 100% = 3.90 gal/hr (vs 3.87 spec)
# Home assistant could compute a gallons/hour rate in a template sensor if this seems useful.
So for example these two entities don’t work:
If I look in MQTT Explorer I see the following for these two. (These are actually from the HA integration, I can’t post more than one picture as a new member)
Message 16 received on generator/Status/Engine/Battery_Voltage at 8:41 PM:
{"unit": "V", "type": "float", "value": 14.0}
QoS: 0 - Retain: false
Message 15 received on generator/Outage/Utility_Voltage at 8:41 PM:
{"unit": "V", "type": "int", "value": 243}
Any suggestions to fix this would greatly be appreciated!
Thanks.
