MQTT & WLED suddenly stopped working in 0.109.x
Not really sure what suddenly changed. Things were working just a few days ago and suddenly noticed today that nothing is getting through to WLED from home-assistant.
I’m using the official MQTT add-on and WLED 0.10.0. I have some saved payloads to call the WLED API, like topic wled/kitchen_leds/api, payload FX=15&R=254&G=246&B=165&R2=21&G2=32&B2=64&A=255&IX=37&SX=73. This used to work, but today, I get no response.
Looking at the add-on’s logs, I see the following:
[ERROR] Auth error with mqtt
1588978564: Socket error on client <unknown>, disconnecting.
1588978593: New connection from 10.0.1.150 on port 1883.
1
So I’m guessing there’s an auth error. Did something change in HA 0.109.x that I missed that would cause this? Any idea where I should start troubleshooting?
More details:
Add-on configuration:
logins: []
anonymous: false
customize:
  active: false
  folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
WLED configuration is using a user/password combo that I created in HA specifically for MQTT.
Ended up removing the integration and the add-on, then re-adding (all with exact same settings) and now everything works.
The age-old “try turning it on and off again” (but the nuclear version)
