MQTT YAML entries
I have manged to find the code for reading sensors and switching relays through mqtt using my Arduino Uno and an Ethernet Shield but am having trouble getting the YAML entries correct.
The IDE code is:
          Arduino UNO with W5100 Ethernetshield or  W5100 Ethernet module, used as MQTT client
          It will connect over Wifi to the MQTT broker and controls a digital output (LED, relay)
          and gives the Temperature and Humidity, as well as the state of some switches
          The topics have the format "home/br/sb" for southbound messages and  "home/nb" for northbound messages
          Southbound are messages going to the client, northbound are messages coming from the client
          As the available memory of a UNO  with Ethernetcard is limited, I have kept the topics short
          Also, the payloads  are kept short
          The Northbound topics are
          home/br/nb/temp  for temperature
          home/br/nb/humid  for humidity
          home/br/nb/deur  for a door switch
          home/br/nb/l for  the lightintensity
          home/br/nb/pr  for the status of a PIR sensor
          home/br/nb/ip showing the IP number of the client
          home/br/nb/relay showing the relaystate
          There is only one southbound topic:
          home/br/sb
          The payload here determines the action:
          0 -Switch the relay off
          1-Switch the  relay on
          2-Publish the IP number of the client
          3 Ask for the relaystate// REMOVED
          On Startup, the Client publishes the IP number
#include <Ethernet.h>// Ethernet.h library
#include "PubSubClient.h" //PubSubClient.h Library from Knolleary
#include "DHT.h" //DHT.h library
#define CLIENT_ID       "Hal"
#define PUBLISH_DELAY   3000 // that is 3 seconds interval
#define DHTPIN          3
#define DHTTYPE         DHT11
#define ledPin 13
#define relayPin 8
String ip = "";
bool statusKD = HIGH;
bool statusBD = HIGH;
bool statusGD = HIGH;
bool relaystate = LOW;
bool pir = LOW;
bool startsend = HIGH;// flag for sending at startup
int lichtstatus; //contains LDR reading
uint8_t mac[6] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x06};
EthernetClient ethClient;
PubSubClient mqttClient;
DHT dht(DHTPIN, DHTTYPE);
long previousMillis;
void setup() {
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  pinMode(7, INPUT);
  pinMode(relayPin, OUTPUT);
  // setup serial communication
  Serial.begin(9600);
  while (!Serial) {};
  Serial.println(F("MQTT Arduino UNO"));
  Serial.println();
  // setup ethernet communication using DHCP
  if (Ethernet.begin(mac) == 0) {
    //Serial.println(F("Unable to configure Ethernet using DHCP"));
    for (;;);
  Serial.println(F("Ethernet configured via DHCP"));
  Serial.print("IP address: ");
  Serial.println(Ethernet.localIP());
  Serial.println();
 //convert ip Array into String
  ip = String (Ethernet.localIP()[0]);
  ip = ip + ".";
  ip = ip + String (Ethernet.localIP()[1]);
  ip = ip + ".";
  ip = ip + String (Ethernet.localIP()[2]);
  ip = ip + ".";
  ip = ip + String (Ethernet.localIP()[3]);
  //Serial.println(ip);
  // setup mqtt client
  mqttClient.setClient(ethClient);
  // mqttClient.setServer("test.mosquitto.org", 1883);//use public broker
  mqttClient.setServer( "192.168.1.3", 1883); // or local broker
  //Serial.println(F("MQTT client configured"));
  mqttClient.setCallback(callback);
  // setup DHT sensor
  dht.begin();
  Serial.println(F("DHT sensor initialized"));
  Serial.println();
  Serial.println(F("Ready to send data"));
  previousMillis = millis();
  mqttClient.publish("home/br/nb/ip", ip.c_str());
void loop() {
  statusBD = digitalRead(4);// FrontdoorSwitch
  statusGD = digitalRead(5);// Garagedoor Switch
  statusKD = (digitalRead(6));//LivingRoom Switch
  lichtstatus = analogRead(A0);//Reads an LDR
  pir = digitalRead(7);//Reads a PIR sensor
  relaystate = digitalRead(relayPin);// Reads the state of a relay
  // it's time to send new data?
  if (millis() - previousMillis > PUBLISH_DELAY) {
    sendData();
  mqttClient.loop();
void sendData() {
  char msgBuffer[20];
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.println("oC");
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.println("%");
  Serial.print("Relay is: ");
  Serial.println((relaystate == LOW) ? "OPEN" : "CLOSED");
  if (mqttClient.connect(CLIENT_ID)) {
    mqttClient.publish("home/br/nb/temp", dtostrf(t, 6, 2, msgBuffer));
    mqttClient.publish("home/br/nb/humid", dtostrf(h, 6, 2, msgBuffer));
    mqttClient.publish("home/br/nb/deur", (statusBD == HIGH) ? "OPEN" : "CLOSED");
    mqttClient.publish("home/br/nb/garage", (statusGD == HIGH) ? "OPEN" : "CLOSED");
    mqttClient.publish("home/br/nb/bel", (statusKD == HIGH) ? "OPEN" : "CLOSED");
    mqttClient.publish("home/br/nb/l", dtostrf(lichtstatus, 4, 0, msgBuffer));
    mqttClient.publish("home/br/nb/p", (pir == HIGH) ? "OPEN" : "CLOSED");
    mqttClient.publish("home/br/nb/relay", (relaystate == LOW) ? "OPEN" : "CLOSED");
    mqttClient.subscribe("home/br/sb");
    if (startsend) {
      startsend = LOW;
void callback(char* topic, byte* payload, unsigned int length) {
  char msgBuffer[20];
  // I am only using one ascii character as command, so do not need to take an entire word as payload
  // However, if you want to send full word commands, uncomment the next line and use for string comparison
  // payload[length]='\0';// terminate string with 0
//String strPayload = String((char*)payload);  // convert to string
  // Serial.println(strPayload);
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");//MQTT_BROKER
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  Serial.println();
  Serial.println(payload[0]);
  // Examine only the first character of the message
  if (payload[0] == 49)             // Message "1" in ASCII (turn output ON)
    digitalWrite(LED_BUILTIN, HIGH);    //
    digitalWrite(relayPin, HIGH);
  } else if (payload[0] == 48)      // Message "0" in ASCII (turn output OFF)
    digitalWrite(relayPin, LOW);     //
    digitalWrite(LED_BUILTIN, LOW);
  } else if (payload[0] == 50)
    mqttClient.publish("home/br/nb/ip", ip.c_str());// publish IP nr
  } else {
    Serial.println("Unknown value");
    mqttClient.publish("home/br/nb", "Syntax Error");
and my current YAML entries are:
sensor 3:
  platform: mqtt
  state_topic: 'home/br/nb/temp'
  unit_of_measurement: 'Ā°C'
sensor 4:
  platform: mqtt
  state_topic: 'home/br/nb/humid'
  unit_of_measurement: '%'
switch 2:
  platform: mqtt
  state_topic: "home/br/nb/relay"
  command_topic: "home/br/nb/relay"
  payload_on: "1"
  payload_off: "0"
  qos: 0
  retain: true
Iā€™m only looking to use the relay switch and DH sensor reading at this stage and would very much appreciate if someone could tell me where Iā€™m going wrong?
This part of the documentation could help you to identity a possible issue with publishing/subscribing.
Gruetzi fabaff!
Thank you for the tip but the testing instructions are Greek to me. I think I know what the problem is with the codeā€¦ I have not included my mqtt username and pasword and have now included them in the client connect code:
if (mqttClient.connect(CLIENT_ID),ā€œusernameā€, ā€œpasswordā€)
but Iā€™m not sure if this is correct because I still havenā€™t got it to work?
So what is the output from the arduino?
This is the output on my serial monitor:
MQTT Arduino UNO
IP address: 192.168.1.15
Ready to send data
Temperature: 25.00oC
Humidity: 17.00%
Relay is: OPEN
Iā€™m only looking to use the DH sensor and the relay at this stage.
There is no indication from your sketch if it connected to the MQTT broker or not, so its hard to tell what is happening.
I suggest adding some println statements inside the if (mqttClient.connect(CLIENT_ID)) { block, to make sure it does connect.
You could also check the broker log to see if it is receiving a connection with id ā€˜halā€™
If it is connecting , then I suggest using another client (such as mosquitto_sub) to read the data being sent to the broker. This works for me (on the same machine as the broker)
mosquitto_sub -t "#" -v
Hello, did you get it to work?, i need it for 4 relay and 1 dht temperature sensor, please help
No, I gave up on the ethernet connection and replaced it with an esp8266.
My arduino coding was too rubbish.
