Today on iBood in Belgium, there offering a Mr Safe Smart Home Socket Set.
Does anyone know that they can work with Home Assistant?
I already find out that the base plug will work over WiFi and the other are connected to the base station with RF.
This is the website of the product: http://www.mrsafe.be/?portfolio=smart-home-socket-set
Incase anybody with a Old Mr. safe Doorbell “Mr. safe deurbel” ever comes to this message then I have found my doorbel sents out a 433Mhz message (captured with RFLink) with the following code:
This way you could add the doorbell press event to Home assistant.
In the HA config I created a switch with this code and use it to sent a chime message to google speakers around the house. This switch is used in that automation that rings the speakers and I reset the switch after that.
