MS Office 365 Integration (HACS) - problem with URI
Hi folks,
I am little bit stucked (actually for few days :-)) within authorization process.
I have installed duckdns and nginx add-ons a week ago, and my router port forwarding is set from outer duckdns 8088 to 443 inside. HTTPS approach to hass is going pretty well.
In Azure environment I set URI address as a https://:8088/api/o365, and in a configuration.yaml I had set bare http: row only - according this https://help.konnected.io/support/solutions/articles/32000023964-set-up-hass-io-with-secure-remote-access-using-duckdns-and-nginx-proxy (without any basic_url).
I am not able (like a newbie) to find what is wrong, in every try there is only one answer - invalid_request: The provided value for the input parameter redirect_uri is not valid. The expected value is a URI which matches a redirect URI registered for this client application.
Can anybody help me? Some suggestion or hint? Probably there is a problem between a chair and a keyboard I suppose.
Really appreciated any hint …
