Hi there. I apologize if I am in the wrong spot, but didnt know exactly where to start.
I have the latest version of Home Assistant running, and I have installed Eufy Security, Go2RTC and the WebRTC integrations.
I have used the documentation from github for adding cards and they work for the most part…
If I use this setup below, then the rtsp stream runs no matter what and it times out after a few minutes and you can’t get it to start again without going into the Eufy App and toggling on/off the RTSP feature for that camera. The error that pops up is “mse: streams: wrong response on DESCRIBE”
AND if I use this alternate configuration below, I get an error that says “can’t get url for camera.xx” and I don’t know why, or where to find the url. I checked the entities of the camera as well and it does in fact show me the stream url and rtsp url. So I know they are there.
Can someone people tell what I may be missing, need to add or what might be wrong?
Ultimately I would like to be able to open the dashboard and play the rtsp streams at the push of a button and stop them accordingly OR maybe it makes sense for them to start auto playing when the dashboard is being viewed only?
I’m having the same issue since the beginning. I also tried different configurations and it still the same. Sometimes, restarting the addon (eufy-security-ws) fixes and the cameras start working but just for a few minutes.
The firmware of my HomeBase 2 is up-to-date (v3.3.4.1h).
I solved the issue by running the “Start streaming via RTSP” entity provided by the device.
After breaking my head, I found an excellent video explaining how to make it work here:
Thank you for sharing that! It is really useful video and it works like a charm when motion is detected, etc. - however I did not see being addressed a continuous streaming where there is no motion…
Yet, the video gave me a hint and I managed to fix this pesky error, by creating a simple automation of “time trigger”, where the RTSP stream is continuously turned on (i noticed the stream “expires” usually after 5 minutes and then the thumbnail breaks)
I wish I found this post earlier! I’ve been banging my head against the desk for hours before finally arriving at the same conclusion. Although I trigger my automation every 5 minutes rather than 1 minute and that seems to be frequent enough. The only issue is now it has to be a continuous stream which I cant stop otherwise it juts starts again after 5 minutes.
Still sometimes the screen stayed black. I figured that by clicking on the text in the upper right corner (usually “MJPEG” or “error”) the stream would change to MSE, which is the mode that works without lags. This mode can also be configured in the custom WebRTC component by adding:
