Hello everyone,
I recently exposed H.A. through Cloudflare tunnels and MTLS (ECC), it works just fine from the Android’s application, using a client certificate.
I expected to be able to do the same for my watch (Xiaomi Watch 2 Pro), because of Add Wear OS TLS client certificate authentication (TLS CCA) support.
But it fails with “Could not register watch” and logs say:
04-14 22:34:24.515 15199 15199 E SettingsWearViewModel: Watch was unable to register: java.io.IOException: exception decrypting data - java.security.NoSuchAlgorithmException: 1.2.840.113549.1.5.12 SecretKeyFactory not available
Here’s what openssl says about the certificate:
PKCS7 Data
Shrouded Keybag: PBES2, PBKDF2, AES-256-CBC, Iteration 2048, PRF hmacWithSHA256
Has anyone succeeded in doing so on a Xiaomi watch, and is there something I could be doing wrong ?
Thank you
