Mui board with HA
Hi
Anybody already tried to integrate and control the Mui board from Mui labs with HA?
https://muilab.com/en/products_and_services/muiboard/
It is a matter device and as far as I see it should be possible to be integrated as written here:
https://www.home-assistant.io/integrations/matter/#adding-a-matter-device-to-home-assistant
I would like to control some switches from the board and show some sensor data on the Mui board. Is it possible?
Because it is quite expensive, I would like to check that first before buying.
Thanks in advance
Lukas
Up.
I am Interested…
I guess you did not find a solution?
I got the board.
It’s is a super cool piece of tech. However, right now it doesn’t support matter bridges.
You can connect it to native matter devices no problem. But bridging any other HA supported device via the matter bridge willl get you nothing. Their support site states that the board doesn’t support bridges “yet”…
