Muller Intuitiv with Netatmo via HomeKit
Hi everyone,
Is anyone using the Muller Intuitiv with Netatmo via HomeKit controller integration?!
My heaters have motion sensors. The integration only provides a climate sensor per heater. Any clue how to access it?
Same thing with the power consumption given in the official app!
Thanks!
Is there anyone who could help on that? I would really appreciate it! :relaxed:
hello,
what are the step to follow to get the Intuitiv gateway connected ?
does it conflict with using the Intutiv android application to control the heaters ?
Thanks a lot
Hello there! I’m in the same boat, and interested by that question as well.
@fyah did you find a way to connect your heaters?
@mgim by any chance if have more information.
Thanks!
May you precise the procedure to pair it with homekit pls ?
It keeps failing for me…
My problem was related to my setup. I was using HA via a TrueNAS Scale application, and HA was detecting some devices but not everything.
I switched to a dedicated VM with HAOS, and everything was detected without any setup.
Thanks for your answer. Has anyone found a solution to make it work with HA supervised ? Mine is running on a fresh installation of debian 12.
Are you having issues with other integration on your network? Maybe your default firewall settings on debian 12 are not allowing what’s necessary?
