šŸ” Multi Click Button - Make any button multi-clickable
Get it now:
Introduction:
Allows multi-click actions to take place on a button.
Upon reaching the number of required clicks, it executes user defined actions.
  • Double click a button to turn on a light?
  • Quintuple click a button to turn off the alarm?
  • Centuple (Yes, 100 times!) flick a switch to reveal a hidden closet?
This and much more is possible with this Blueprint.
How it works:
  1. Select your button.
    (There are 3 entity types supported: button, input_button and switch)
  2. Set home many ā€˜clicks’ your button needs to make before the actions are executed.
    (Every state change is counted as a click. Therefore, in switch entity types, both turning it on or off is counted as a ā€˜click’.)
  3. Set how much time there can be between clicks.
  4. Set actions to execute
  5. (OPTIONAL) Add conditions that need to be met before executing the actions.
Most recent version:
1.4:
:link: Source code (Github)
:gear: See code changes (Github)
:memo:Changelog:
24/07/2025 - Version 1.4
  • Amended syntax to new guidelines (HA 2024.8 & 2024.10 changes)
See older changes
09/01/2025 - Version 1.3
06/09/2024 - Version 1.2
  • Updated the time between click selector to the new duration selector with millisecond support. (Requires Home Assistant 2024.8 and newer).
09/01/2024 - Version 1.1
  • Removed an unneeded logger action that was used in development
09/01/2024 - Version 1.0
  • Original release
NEW RELEASE:
Hi, I’m new to this forum and also to using blueprints. I really like the idea of running multiple actions with just one button, thanks for the work you are sharing here!
The problem I have is that if I have, for example, one automation for 2 clicks and another for 3 clicks, if I want the one for 3 clicks to run, it always runs the first automation with 2 clicks first. Is that correct? And is there a way to ensure that only the correct automation is executed?
Thanks! Mario
That’s correct. The blueprint doesn’t know how many automations it’s used in.
This means that if you use the same button for a double click and a triple click and you click the button 3 times, then both triggers will be fulfilled and both automations will run.
Ok, I got it. Maybe I would have to select the 3x automatic with a larger timeout so that the 2x expires. If I want the 3x action, I would have to press slowly.
The 2 click automation (2CA) would need to expire twice actually.
Let’s say you set the double click timer to 1 second between clicks and the triple click to 2 seconds between clicks:
You click once and wait for more than 1 second to let 2CA expire, then you click a second time, after which you will need to let the 2CA expire again before clicking the 3rd time.
So it’s possible, but a little convoluted.
Perfect, trank you for the feedback and support.
Is there any reason you didn’t include ā€œlightā€ entities as well? I have a couple dimming switches that aren’t just binary. They do have on/off state, though, so there shouldn’t be an issue here, as far as I know.
I’d like this too. I have now manually created something similar but would love to use a blueprint for this. I’m using a Shelly dimmer in the light domain.
The trigger I’m using:
  - platform: device
    device_id: da83ac5220cbff4807e1f1d2ee04cd9f
    domain: shelly
    type: single
    subtype: button1
The way it currently works is that every state change will count as a ā€˜click’. So I think you might have issues where every time the dimming value is changed it will count that as a ā€˜click’ too.
Can you add Long Press too?
The problem with adding a long press function is that you need to know when the press started and stopped. That’s not possible with most switches unfortunately.
NEW RELEASE:
i am looking for the solution which will save me some space in the dashboard.
Basically I need 1 click to the ā€œblinders upā€ to run script to move blinders about 20°, and double click would open on close them totally. But whatever i do doubleclick action is always trigger also single click automation. Which overide that function.
I dont understand previous comment how to solve this. Or isn“t it somehow upgradable to add this logic ?
NEW RELEASE
Sorry for getting back to you so late. It’s been a very busy couple of months.
You have to have your 1 click automation wait and check if the button is pressed a second time before executing.
Tnx a lot for your blueprint.
I am using it, but i have a little problem.
I have One and Double click for a input_bullean
Problem is: When double click it executes also simple click 2 times.
How could i prevent it?
Thank’s
please… could you send an example? (screenshot)
You need to set a delay for the simple click action. the delay needs to be longer than the maximum time allowed between the 2 clicks of the double click input.
NEW RELEASE:
