I recently got a dinosaur night light for my kids, that is controlled by an IR remote. Also I have a floor fan (Honeywell/Kaz hy254tgt “Quietset”) that is controlled by IR that I keep in their room as it gets hotter in the summer.
My goal was is to be able to modify the night light settings (color/brightness/on/off) as well as fan speed.
I picked up one of the IR shields for a D1 mini, and came up with the following for ESPHome. I create a representation of the night light and the fan. As long as they’re not controlled by real remotes or physical buttons they work pretty well. I thought i’d share in case this turns out to be helpful to anyone else with similar goals!
I also was going to put a DHT on to better decide on fan speeds but i’m finding that either wifi interference or heat on the D1 mini is making it unreliable. Any advice there is welcome!
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_front_ssid
password: !secret wifi_front_password
fast_connect: on
ap:
ssid: "Kids IR Fallback Hotspot"
password: !secret fallbck_hotspot
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
globals:
- id: previous_dino_state
type: float
- id: previous_fan_state
type: float
- id: previous_fan_osc_state
type: float
remote_transmitter:
pin: D3
# Infrared remotes use a 50% carrier signal
carrier_duty_percent: 50%
fan:
- platform: speed
output: fan_power_output
oscillation_output: fan_osc_output
speed:
low: 0.25
medium: 0.5
high: 1.0
light:
- platform: monochromatic
name: "Dinosaur Night Light"
default_transition_length: 0s
output: dino_output
effects:
- lambda:
update_interval: 30s
lambda: id(green).execute();
- lambda:
lambda: id(red).execute();
- lambda:
lambda: id(blue).execute();
- lambda:
lambda: id(white).execute();
- lambda:
lambda: id(flash_pattern).execute();
- lambda:
lambda: id(fade_pattern).execute();
- lambda:
lambda: id(strobe_pattern).execute();
- lambda:
lambda: id(smooth_pattern).execute();
output:
type: float
write_action:
- lambda: |-
ESP_LOGD("brightness", "previous state: %f, new state %f", id(previous_dino_state), state);
/* turning off */
if (state == 0) {
id(turn_off_dino).execute();
} else {
/* turn on */
if (id(previous_dino_state) == 0) {
id(turn_on_dino).execute();
/* adjust brightness - 5 increments*/
if (id(previous_dino_state) < state) {
for (float i=id(previous_dino_state); i <= state; i+=.15) {
delay(300);
id(brightness_up).execute();
} else {
for (float i=id(previous_dino_state); i >= state; i-=.15) {
delay(300);
id(brightness_down).execute();
id(previous_dino_state) = state;
type: float
write_action:
- lambda: |-
ESP_LOGD("fan", "previous state: %f, new state %f", id(previous_fan_state), state);
/* turning off */
if (state == 0) {
id(toggle_fan_power).execute();
} else {
/* turn on */
if (id(previous_fan_state) == 0) {
/* adjust speed - need to map 5 increments to 3*/
if (id(previous_fan_state) != state) {
int steps = 0;
float old_state = id(previous_fan_state);
/* H->L */
if ((old_state > 0.75) && (state == 0.25)) {
steps = 1;
/* 0->M, L->M, M->H */
} else if (((old_state < 0.25) && (state == 0.50)) ||
((old_state == 0.25) && (state == 0.50)) ||
((old_state == 0.50) && (state == 1.00))) {
steps = 2;
/* M->L, H->M */
} else if (((old_state > 0.75) && (state == 0.50)) ||
((old_state == 0.5) && (state == 0.25))) {
steps = 3;
/* 0->H, L->H */
} else if (((old_state < 0.25) && (state == 1.0)) ||
((old_state == 0.25) && (state == 1.0))) {
steps = 4;
ESP_LOGD("fan", "%d increment steps", steps);
for (int i=0; i < steps; i++) {
delay(300);
id(increment_fan_speed).execute();
id(previous_fan_state) = state;
type: float
write_action:
- lambda: |-
ESP_LOGD("fan osc", "previous state: %f, new state %f", id(previous_fan_osc_state), state);
if (id(previous_fan_osc_state) != state) {
id(toggle_fan_oscillate).execute();
id(previous_fan_osc_state) = state;
script:
- id: brightness_up
then:
- remote_transmitter.transmit_lg:
data: 0x00FFA05F
nbits: 32
- id: brightness_down
then:
data: 0x00FF20DF
nbits: 32
- id: turn_on_dino
then:
#turn on light
data: 0x00FFE01F
nbits: 32
- id: turn_off_dino
then:
#turn off light
data: 0x00FF609F
nbits: 32
- id: smooth_pattern
then:
#set smooth pattern
data: 0x00FFC837
nbits: 32
- id: fade_pattern
then:
#set fade pattern
data: 0x00FF609F
nbits: 32
- id: strobe_pattern
then:
#set strobe pattern
data: 0x00FFD827
nbits: 32
- id: flash_pattern
then:
#set Flash pattern
data: 0x00FFE817
nbits: 32
- id: red
then:
#set red pattern
data: 0x00FF906F
nbits: 32
- id: green
then:
#set green pattern
data: 0x00FF10EF
nbits: 32
- id: blue
then:
#set blue pattern
data: 0x00FF50AF
nbits: 32
- id: white
then:
#set white pattern
data: 0x00FFD02F
nbits: 32
- id: toggle_fan_power
then:
#turn on or off the fan
- remote_transmitter.transmit_raw:
code: [+1259,-402,+1259,-402,+402,-1259,+1259,-402,+1259,-402,+402,-1259,+402,-1259,+402,-1259,+402,-1259,+1259,-402,+402,-1259,+402,-8087]
carrier_frequency: 37344
- id: increment_fan_speed
then:
#increment the fan's speed (starts at 1 goes to 5 and then wraps)
code: [+1259,-402,+1259,-402,+402,-1259,+1259,-402,+1259,-402,+1259,-402,+402,-1259,+402,-1259,+402,-1259,+1259,-402,+1259,-402,+402,-8087]
- id: toggle_fan_oscillate
then:
#toggle the oscillation mode of the fan
code: [+1259,-402,+1259,-402,+402,-1259,+1259,-402,+1259,-402,+1259,-402,+402,-1259,+402,-1259,+402,-1259,+402,-1259,+1259,-402,+1259,-7230]
#Disable until needing to program more
#remote_receiver:
# pin:
# number: D4
# #D1 mini IR shield needs to be flipped
# inverted: True
# dump: all
switch:
#this is here since fan.oscillate() service from HA seems to not be working
name: QuietSet Fan Oscillate
turn_on_action:
#unused color patterns
#switch:
# - platform: template
# name: Kids Night Light Red-Orange
# turn_on_action:
# - remote_transmitter.transmit_lg:
# data: 0x00FFB04F
# nbits: 32
# name: Kids Night Light Orange
# turn_on_action:
# data: 0x00FFA857
# nbits: 32
# name: Kids Night Light Orange-Yellow
# turn_on_action:
# data: 0x00FF9867
# nbits: 32
# name: Kids Night Light Yellow
# turn_on_action:
# data: 0x00FF8877
# nbits: 32
# name: Kids Night Light Light green
# turn_on_action:
# data: 0x00FF30CF
# nbits: 32
# name: Kids Night Light Aquamarine
# turn_on_action:
# data: 0x00FF28D7
# nbits: 32
# name: Kids Night Light Aquamarine Green
# turn_on_action:
# data: 0x00FF18E7
# nbits: 32
# name: Kids Night Light Dark Green
# turn_on_action:
# data: 0x00FF08F7
# nbits: 32
# name: Kids Night Light Light blue
# turn_on_action:
# data: 0x00FF708F
# nbits: 32
# name: Kids Night Light Purple
# turn_on_action:
# data: 0x00FF6897
# nbits: 32
# name: Kids Night Light Mauve
# turn_on_action:
# data: 0x00FF58A7
# nbits: 32
# name: Kids Night Light Pink
# turn_on_action:
# data: 0x00FF48B7
# nbits: 32
