Multi-floor buttons not functioning
I have a multi floor floorplan where the 3 floor buttons change the visibility of each level. I had it all working, haven’t touched in a couple weeks so I’m not sure the last thing I change. Now the floor buttons do not function, when I hover the mouse over the cursor doesn’t change, and they do not function. There are no errors in the debug. I’ve tried for hours now to figure out what i broke. I even tried going back to the simple rectangle buttons from the example.
The startup action seems to be working as it changes buttons 2 and 3 to red.
The CSS seems to be working on the buttons as when it initial loads it changes the button text to white. Each floor button has a red object and a green object to show which floor is active.
the room at the top right has an overlay for a button and that is working fine, its just the floor buttons.
here is my yaml
title: OBX Floorplan
  - title: OBX Floorplan
    path: floorplan
    panel: true
    type: panel
    theme: Google Dark Theme
    badges: []
    cards:
      - config:
          log_level: debug
          defaults:
            hover_action: hover-info
            tap_action: more-info
          image: /local/floorplan/multi_floor/obx_floorplan_ha_r4.svg
          cache: false
          startup_action:
            - service: floorplan.class_set
              service_data:
                element: ground_floor
                class: layer-visible
              service_data:
                elements:
                  - first_floor
                class: layer-hidden
              service_data:
                elements:
                  - second_floor
                class: layer-hidden
              service_data:
                elements:
                  - green-button-1
                  - red-button-2
                  - red-button-3
                class: button-on
              service_data:
                elements:
                  - green-button-2
                  - green-button-3
                class: button-off
          rules:
            - entity: switch.bed3_main_light
              element: bed3-main-overlay
              tap_action: toggle
              state_action:
                action: call-service
                service_data: entitystate-${entity.state}
              element: bed3-main-lights
              tap_action: toggle
              state_action:
                service_data: light-${entity.state}
            - entity: switch.bed3_fan
              element: pwdr-fan-blades
              tap_action: toggle
              state_action:
                  service_data:
                    class: bathfan-${entity.state}
              element: pwdr-fan
              tap_action: toggle
              state_action:
                  service_data:
                    class: '${(entity.state === "on") ? "spinning" : ""}'
            - element: ground-floor-button
              tap_action:
                  service_data:
                  service_data:
                    elements:
                      - first_floor
                      - second_floor
                    class: layer-hidden
                  service_data:
                    elements:
                      - green-button-1
                    class: button-on
                  service_data:
                    elements:
                      - green-button-2
                      - green-button-3
                    class: button-off
            - element: first-floor-button
              tap_action:
                  service_data:
                    element: first_floor
                  service_data:
                    elements:
                      - ground_floor
                      - second_floor
                    class: layer-hidden
                  service_data:
                    elements:
                      - green-button-2
                      - red-button-1
                    class: button-on
                  service_data:
                    elements:
                      - green-button-1
                      - green-button-3
                    class: button-off
            - element: second-floor-button
              tap_action:
                  service_data:
                    element: second_floor
                  service_data:
                    elements:
                      - first_floor
                      - ground_floor
                    class: layer-hidden
                  service_data:
                    elements:
                      - green-button-1
                      - green-button-2
                    class: button-off
                  service_data:
                    elements:
                      - green-button-3
                    class: button-on
          stylesheet:
            location: /local/floorplan/multi_floor/obx_multi_floor.css
            cache: false
        full_height: true
        type: custom:floorplan-card
  - title: Sample Entities
    path: sample-entities
    icon: ''
    badges: []
    cards:
      - type: entities
        entities:
            name: Office Light (switch.office_light)
            name: Office Fan (switch.office_fan)
        title: Test Entities
        state_color: true
my SVG
Have you tried a different browser? Have you tried clearing the browser cache? Have you tried inspecting the page using the browser tools to see if the classes are getting applied?
Yes to all. Same result in Edge, I’m using Chrome. I have to clear the cache everything I make a change to my SVG. I have a revision number on it so I make sure i’m looking at the latest SVG.
the css is being applied to The text of the buttons.
I’m sure its a yaml issue I just cannot see.
What version of ha-floorplan are you using? There was a recent update to 1.0.40. If it previously worked then something has changed. I do note the way you are doing the setting of classes is different to the way I am doing it. I have five layers but I will will just paste in how I am doing my three layers. Hopefully you will be able to see how it works
CSS extract
#layer1.amp-layer-visible, #layer1.amp-layer-visible * {
  opacity: 1;
  display: inherit !important;
#layer2.amp-layer-visible, #layer2.amp-layer-visible * {
  opacity: 0;
  display: none !important;
#layer3.amp-layer-visible, #layer3.amp-layer-visible * {
  opacity: 0;
#layer2.projector-layer-visible, #layer2.projector-layer-visible * {
  opacity: 1;
#layer1.projector-layer-visible, #layer1.projector-layer-visible * {
  opacity: 0;
#layer3.projector-layer-visible, #layer3.projector-layer-visible {
  opacity: 0;
#layer3.kodi-layer-visible, #layer3.kodi-layer-visible * {
  opacity: 1;
#layer2.kodi-layer-visible, #layer2.kodi-layer-visible * {
  opacity: 0;
#layer1.kodi-layer-visible, #layer1.kodi-layer-visible * {
  opacity: 0;
YAML extract
      startup_action:
          service_data:
            class: amp-layer-visible
            elements:
              - layer1
              - layer3
              - layer2
        - element: amp.button
          tap_action:
              service_data:
                classes:
                elements:
                  - layer1
                  - layer3
                  - layer2
        - element: projector.button
          tap_action:
              service_data:
                classes:
                class: projector-layer-visible
                elements:
                  - layer1
                  - layer3
                  - layer2
From The Chrome Console
Floorplan for Home Assistant (ha-floorplan)Version 1.0.37
in HACS it show 1.0.39
one of my issues was an overlay not working. When i edited the yaml to point to a different overlay it worked. I duplicated the working overlay and named it the overlay that wasn’t working and that fixed it. This is very weird, along The same lines as I mentioned before that copy/pasted elements do not respond. I know you think I’m mistaken but I verified this behavior several times.
I’m using Inkscape 1.0.1. I’m downloading the latest version now.
Caching problems can cause weird behaviours like this as well…
