You can work it backwards from entity_id also using devices in your automation will lead to pain. Especially in voice process ing because the llm context does jot contain device_ids.
What are you ACTUALLY trying to accomplish and someone can help you work it out.
as I said, in the opener:
I hve an intent that waits for an external process to finish (its an MQTT command and reply) with a timeout of 10 seconds. In the meantime I would like to respond with “OK, understand, please wait…” on that speaker as part of the reply - which follows after 10s (max)
I am not sure I understand the question.
The intent is triggered with “Hey Nabu, play .”
The code then send an mqtt command and waits for an MQTT reply (a publish to homeassistant), uses the data to generate an AI reply and puts that into the speech: text
PlaylistSelect:
- variables:
area: "{{ area }}"
QueueCtrl: "{{ QueueCtrl | default('queue') }}"
Playlist: "{{ Playlist | default('Everything')}}"
- variables:
play_request_dict: >-
"QueueCtrl": QueueCtrl,
"Playlist": Playlist
- variables:
request_id: "r{{ now().strftime('%Y%m%d%H%M%S%f') }}"
- service: script.log
message: "[PlaylistSelect] Requesting playlist '{{ Playlist }}' with QueueCtrl='{{ QueueCtrl }}' in area '{{ area }}'"
## HERE would be nice to inform the user that it might take some time
# this might take some time to complete
- service: script.smartflat_mqtt_request_and_respond
cmd_topic: "PlaylistSelect"
payload: "{{ play_request_dict | tojson }}"
task_name: "PlaylistSelect"
Description: "Inform the user about the prepared songs. Summarize the information about the included songs into a very short sentence, choosing two or three of the result parameters."
request_id: "{{ request_id }}"
response_variable: reply_payload
- variables:
result: >-
{{ (reply_payload.result if reply_payload is mapping else (reply_payload | default(''))) | default('') }}
- stop: ""
response_variable: result
## now provide the reponse fromt he external tool (that gets delivered by smartflat_mqtt_request_and_respond
speech:
text: "{{ action_response }}"
Move your automation from intent_script to the GUI. Then you will have access to standard methods for obtaining the trigger ID {{ trigger.device_id }}.
And also, LLM still hasn’t learned that we’ve moved from service to action
There is also a way for intent_script, but it is more complicated and requires filtering by name. Here is a minimal example. If an announcement action is required, then the domain in the request must be changed.
Also, the final speech block cannot be placed, otherwise there will be problems with playback.
So, I finally took the time to build this and test it and can confirm it works within intent_scripts as well.
as outlined by @mchk it requires the “area” slot in the intent to provide the area where the user ask spoken.
This needs to be mapped to a output device (either via the search in the example above or with a mapping table).
You can then use tts.speak in the intent, do your stuff and (at least working for me) than use the final speech block of the intent to return to actual output. If the Intent finishes too quick then it will abort the tts.speak and speak its text.
