Multi Selection in a drop-down
I started with node-red and like the automation you can do with it.
I use home assistant mostly for front end for my family with different users and in back end node red, for the most (not always since home assistant have some good integration of many products) anyway I want as in node-red to create a drop-down menu where I can choose/tag different fixed parameters and I just need this since in node-red I get over all entity status/changed the status of this drop-down what is tagged or not and can then manipulate in node-red what I want to do. I don’t want to know a workaround with multi switches, I’m aware of there are other ways but I want a drop-down or a fixed list where you tag/untag the fixed pre-deffined values/parameter from me. In node-red the drop-down looks like this and something approx the same in HA, if it’s possible, if not it is also a clear info then I will make a card with the needed switches as yes/no true/false but takes more place and I want to work with arrays here, anyway that is my question is a drop-down with multi chooses possible?
Thx in advance
Per
