Multi sensor updates
Hey all
Just added some aeon multi sensors .
Everything seems great ( humidity , temp , lux ) report . Presence works as expected .
The humidity , temp no, lux though don’t seem to update . I can’t see any obvious issues - but it’s now been days with no change in their reading . Any suggestions appreciated!
Look at the device configuration. There are many parameters that control the updates.
Hi
I can see that . But I can’t find any description that tells me what each attribute does and what values are acceptable.
Searching the forum suggests that the temperature is only correct at point of pairing .
Can’t find any more upto date help on getting this reporting correctly .
You may have better luck posting this in the zigbee forum
