Something I frequently want to program my buttons to do is to toggle a set of lights. If any of the lights are on, they should all turn off. Otherwise, they should all turn on.
I would like to create a re-usable script for this use case, but I’m struggling with what to put in the if:
sequence:
- if:
- condition: template
value_template: "{{ target | select(\"is_state\", \"on\") | first }}"
then:
- action: homeassistant.turn_off
metadata: {}
data: {}
entity_id: "{{ target }}"
else:
- action: homeassistant.turn_on
metadata: {}
data: {}
fields:
selector:
entity:
multiple: true
required: true
alias: Smart Toggle
description: >-
Toggle the state of a set of entities. If any one is on, turns them all off.
Otherwise, turns them all on.
Unfortunately, this doesn’t work. The else branch always executes. How can I write a template that works with the incoming field properly?
