Hi guys,
Building a new home and installing floor water heating. In need of some points, ideas, and even better, someone that already did it. I am based in EU so would like not to use stuff that is very hard to find…
So I have a gas furnace, that will deliver hot water to a manifold from where all the underfloor pipes will go.
The proposed solution was to use a pre-made package, with actuators, control unit and room thermostats.
ex: Quantum controls | Continal Underfoor Heating
I would like to integrate it in HA using ZHA (or something else) but not sure what control unit that can be paired with what thermostats should I look for.
I did find a couple of supported zigbee thermostats on blakadder but that is about it.
Any right direction ?
Thanks!
@itmp I am sorry to see that you haven’t got any replies because I have almos exactly the same problem
What HW have you selected to your floor heating project?
Maybe better way is to invest in pre-made set and just integrate it with HA however here there are so many choices and I cannot check before buying how the integration with HA will work.
If anybody had experience with integrating floor heating control system with HA or implementing the control on HA I would really appreciate your input!
