MultiChannel ADS1115 ESPHome Energy Monitor with CT_CLAMPS
Hi, First post so please be gentle - Just really getting into Home Assistant and playing with sensors, trying to setup a energy monitor and whilst I have this working on 1 channel I want to get all four working.
Setup - Home Assistant on Docker (Raspberry Pi), D1 Mini flashed with ESPHOME, MottramLabs 4 channel ADS1115 and 4x CT013 Clamps
My code as per below … Any pointers on getting the other 3 sensors working would be appreciated as I’ve hit a brick wall trying to search for something to help…
# energy.yaml
# 2022-11-15 -
# Standard YAML Stuff
esphome:
  platform: ESP8266
  board: d1_mini
# Enable Logger
logger:
# Enable Home Assistant API
api:
# Over the Air Password
ota:
  password: ""
# Network Configuration
wifi:
  networks:
  - ssid: "xxxxxxx"
    password: "xxxxxxx"
  # Fallback hotspot in case Wifi connection fails
  ap:
    ssid: "espfallback"
    password: ""
# Config
captive_portal:
# Web Server
web_server:
  port: 80
  auth:
    username: xxxxxxx
    password: xxxxxxx
# Time Services
time:
  platform: sntp
# Hardware Control
i2c:
  sda: 4
  scl: 5
  scan: true
# Module
ads1115:
  - address: 0x48
# Sensors
  # Input Sensor (Clamp)
  - platform: ads1115
    multiplexer: "A0_GND"
    gain: 6.144
    name: "ADS1115 Channel A0-GND"
  # Read a known voltage from Home Assistant to get a more accurate running position
  - platform: homeassistant
    entity_id: sensor.g_dc1_energy_voltage
  # Daily Totals Sensor
  - platform: total_daily_energy
    name: "Total Daily Energy CH0"
    power_id: my_power0
    unit_of_measurement: "kWh"
  # Clamp Sensor
  - platform: ct_clamp
    sensor: adc_sensor0
    name: "Home Current CH0"
    update_interval: 5s
    filters:
    -  calibrate_linear:
       - 0 -> 0
       - 0.02345 -> 4.646
  # Return Sensor
    name: "Home Power CH1"
    lambda: return id(livesensor0).state * id(known_volts).state / 1000;
    update_interval: 5s
Just theory. Have you tried adding another (for channel A1->GND)
- platform: ads1115
    multiplexer: "A1_GND"
    gain: 6.144
    name: "ADS1115 Channel A1-GND"
 # Clamp Sensor
    sensor: adc_sensor1
    id: livesensor1 // changed
    update_interval: 5s
    filters:
    -  calibrate_linear:
       - 0 -> 0
       - 0.02345 -> 4.646
etc.
replacing every 0 in name or id with 1?
How did you get on with this?
This is the code I am running that is working …
ads1115:
1st ADS1115 (ADDR → Grnd)
  • address: 0x48
Channel 1
  • platform: ct_clamp
    sensor: ads1115_1_a0
    name: “NRG-ESP-1 House Current”
    update_interval: 15s
    filters:
    • calibrate_linear:
      • 0 → 0
      • 0.00049 → 0.017
      • 0.01984 → 3.842
      • 0.02096 → 3.931
      • 0.02421 → 4.656
      • 0.04293 → 8.475
      • 0.05668 → 11.16
    When Current updates, update Watts
    on_value:
    then:
    - sensor.template.publish:
    # home_voltage is taken from a TasMota Plug in G_DC1
    state: !lambda ‘return id(current_ch1).state * id(home_voltage).state;’
  • platform: ads1115
    ads1115_id: ads1115_1
    multiplexer: ‘A0_GND’
    gain: 6.144
    internal: true
Channel 2
    sensor: ads1115_1_a1
    name: “NRG-ESP-2 Kitchen Current”
    filters:
    • calibrate_linear:
      Sensor map 0.0 (from sensor) → 0.0 (true value)
      • 0 → 0
      • 0.00049 → 0.017
      • 0.01984 → 3.842
      • 0.02096 → 3.931
      • 0.02421 → 4.656
      • 0.04293 → 8.475
      • 0.05668 → 11.16
    on_value:
    then:
    state: !lambda ‘return id(current_ch2).state * id(home_voltage).state;’
  • platform: ads1115
    multiplexer: ‘A1_GND’
    gain: 6.144
    internal: true
Channel 3
    sensor: ads1115_1_a2
    name: “NRG-ESP-3 Exterior Current”
    filters:
    • calibrate_linear:
      • 0 → 0
      • 0.00049 → 0.017
      • 0.01984 → 3.842
      • 0.02096 → 3.931
      • 0.02421 → 4.656
      • 0.04293 → 8.475
      • 0.05668 → 11.16
    on_value:
    then:
    state: !lambda ‘return id(current_ch3).state * id(home_voltage).state;’
  • platform: ads1115
    multiplexer: ‘A2_GND’
    gain: 6.144
    internal: true
Channel 4
    sensor: ads1115_1_a3
    #filters:
    - calibrate_linear:
    - 0 → 0
    - 0.02344 → 4.648
    on_value:
    then:
    state: !lambda ‘return id(current_ch4).state * id(home_voltage).state;’
  • platform: ads1115
    multiplexer: ‘A3_GND’
    gain: 6.144
    internal: true
Template Sensors for Watts
  • platform: template
    name: “NRG-ESP-1 House Watts”
    lambda: return {};
    unit_of_measurement: W
    accuracy_decimals: 0
    device_class: power
    name: “NRG-ESP-2 Kitchen Watts”
    lambda: return {};
    device_class: power
    name: “NRG-ESP-3 Exterior Watts”
    lambda: return {};
    device_class: power
    lambda: return {};
    device_class: power
Total
    name: “NRG-ESP Total Watts”
    lambda: |-
    return (id(watts_ch1).state + id(watts_ch2).state + id(watts_ch3).state + id(watts_ch4).state);
    device_class: power
    update_interval: 30s
Energy Sensors (kWh) for HA Dashboard
  • platform: total_daily_energy
    name: “NRG-ESP-1 House Total kWh”
    power_id: watts_ch1
    filters:
    • multiply: 0.001
      unit_of_measurement: kWh
    name: “NRG-ESP-2 Kitchen Total kWh”
    power_id: watts_ch2
    filters:
    • multiply: 0.001
    name: “NRG-ESP-3 Exterior Total kWh”
    power_id: watts_ch3
    filters:
    • multiply: 0.001
    name: “NRG-ESP-4 Total kWh”
    power_id: watts_ch4
    filters:
    • multiply: 0.001
Voltage from HA
  • platform: homeassistant
    name: “Voltage From Home Assistant”
entity_id: sensor.s_desk_energy_voltage
entity_id: sensor.average_voltage
  • platform: wifi_signal
    name: “NRG-ESP WiFi Signal Sensor”
    update_interval: 60s
  • platform: uptime
    filters:
    • lambda: return x / 3600.0;
      unit_of_measurement: “hrs”
      accuracy_decimals: 2
I’m trying to do similar thing, but I’m not sure how to connect the CT clamp with the ADS1115 and the Weemos D1 mini.
I have try to directly connect the CT clamp between A0 and GND and I retreive some small negative values from ADS1115 input voltage. I also try with this schema and I retreive positive values arround 1.64V without real changes when I change the current.
Could you explain my how you connect your CT clamps in your case and if it works well now ?
Thanks !
I also get a few negative values when I’ve tried, since using these I’ve finally got my energy supplier to replace my smart meters to SMET2 and I’ve treated myself to a Glow device to send MQTT data from the meters to HA. The clamps are still in place as it does give me some other data (I.e. a couple of specific rooms have their own clamp)
Nice ! Could you share with me some details of your CT clamps connections with the ADS1115 and finally the ESP devices ? Do you have some extra components between the ADS and the CT clamps (resistors, capacitors, …) ? May be a photo or a quick & dirty schema could really hep me! Thanks !
help here?
Hi @brenard ,
Did you manage to do it? Do you have any schema?
It’s depending on your ct clamp style. If it’s a mA version, you’ll need a burden resistor to convert to volts for the ads to read.
Then, because the CT clamp will swing 1v to -1v and the ads only reads positive voltage, you’ll need to bias the 3.3v input in half using 2x 10k resistors to 1.65 ish volts (basically 1.65 will be 0 so the ads can read the full ac voltage wave). A cap is used to decouple and stabilize the reference 1.65 voltage.
Here is a diagram with a volt style CT clamp (has a burden resistor added internally). If your ct clamp is amp style, it will need a burden resistor between the CT clamp wires, close to the clamp.
The ADS1115 is wired to the esp using 4 pins; the i2c pins (SDA, SCL), 3.3v and ground. One leg of the CT clamp goes to ADS1115 A0, the other leg gets the 3.3v biased input (0-1.65 is negative, 1.65xx = 0, 1.65-3.3 is positive).
substitutions:
  friendly_name: esp32-dryer
i2c:
  scl: 9
  sda: 8
ads1115:
  address: 0x48
  # Needed for CT clamp
  continuous_mode: on
# pull in data from a hass sensor, in this case, voltage pulled from my washing machine ZigBee power monitoring plug.
    entity_id: sensor.0x70b3d52b600114bb_voltage
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    name: "${friendly_name} - A0 - Voltage"
    accuracy_decimals: 5
    internal: True
    ads1115_id: ads0
    update_interval: 500ms
    # 1V/30A clamp
    sensor: ads_a0
    name: "${friendly_name} - A0 - Raw"
    sample_duration: 300ms
    update_interval: 1000ms
    # 1V/30A clamp
    sensor: ads_a0
    name: "${friendly_name} - A0 - Calibrated"
    # calibrate with a multimeter
    filters:
      # RAW A -> Calibrated A
      - calibrate_linear:
        - 0 -> 0
        - 0.15146 -> 4.00
        - 0.88471 -> 25.90
      - clamp:
          min_value: 0
          max_value: 30
          ignore_out_of_range: false
    name: "${friendly_name} - Watts"
    device_class: power
    state_class: measurement
    # Change int volts = xxx; to whatever your house voltage *should* be.
    # If the hass sensor pulling voltage ever fails, it will default to this value.
    lambda: |-
      int volts = 120;
      if (!(isnan(id(voltage).state))) {
        volts = id(voltage).state;
      return (id(current0).state * volts);
    update_interval: 1s
    # if you have no hass sensor for voltage, remove the hass sensor from above and have this lambda return xxx V
#    lambda: |-
#      int volts = 120;
#      return (id(current0).state * volts);
To convert to watts you’ll need to know the voltage of your house, or you can base it off of whatever your mains voltage is supposed to be (120V AC here in Canada). Change the watts template lambda base voltage to what yours is, or you can use a hass sensor (id: voltage in the above example) if you already have some device pulling in voltage.
To calibrate
The pertinent part is here:
    filters:
      - calibrate_linear:
        - 0 -> 0
        - 0.15146 -> 4.00
        - 0.88471 -> 25.90
      - clamp:
          min_value: 0
          max_value: 30
  • calibrate_linear: 0.15146 -> 4.00 means, when the raw sensor (raw reading from the clamp) is reporting 0.15146 A, a calibrated measuring device is reporting 4.00 A. esphome will take care of the heavy lifting. Notice how I used 3 calibration points for finer tuned results (AFAIK).
  • clamp (naming is a coincidence) will not report values outside of the ct clamps reported range (due to sllght calibration issues). In my case I have a 30 Amp clamp that outputs 1V, so I dont want negative results below 0 or higher readings above 30.
You can use a cheap aliexpress amp clamp style multimeter to calibrate your CT clamps to output acceptable data. In my case I was calibrating using an electric dryer, which isn’t easy because it is not a constant load.
If you can, calibrate using a constant load for a more dialed in output.
Adding a roughly 3 cm wire to the esp32-c3 supermini antenna pad has increased the sign al quite a bit. This PCB has the crystal pretty close to the cap antenna so I used a wire instead. Make sure to put the wire on the correct pad
This thread is one of the top results from Google… so need to correct some information here.
  • You can only get 2 CT clamps per ADS1115 (unless you are ok with ~90% accuracy). So you are better off using A0_A1 and A2_A3.
  • The resistors shift voltage up since the ADS1115 can only read negative to -300mV. So low AMP testing works, but higher will give wrong numbers.
What I would love to know is what is the ideal sample duration for 60hz power with 2 CT clamps on an ADS1115?
I was looking for information about how I can read many CT clamps and my idea was to have 8x ADS1115 to read out 32 clamps on an esp32. Can you please elaborate why it’s limited to 2 clamps on a ADS1115?
Why can ads1115 only use 2 clamps ?
My setup with 4 CT clamps in continuous mode, gets cross readings within the pairs.
with ads1115 you can pair 2ct clamps in differential mode , directly to the ads1115 , so no need to create a voltage divider to bias the voltage to half of the 3.3V
Can you post the setup for that (differential mode). Thanks.
Differential mode is not supported in ESPHome.
Why you think so?
Ct_clamp sensor component likely doesn’t support it though.
i tested differential mode in esphome , i did not succeed , so i used the voltage divider setup again
Explain better so we conclude something. What didn’t work. Ads1115 or ct_clamp component?
