MultiChannel ADS1115 ESPHome Energy Monitor with CT_CLAMPS
I’m trying to do similar thing, but I’m not sure how to connect the CT clamp with the ADS1115 and the Weemos D1 mini.
I have try to directly connect the CT clamp between A0 and GND and I retreive some small negative values from ADS1115 input voltage. I also try with this schema and I retreive positive values arround 1.64V without real changes when I change the current.
Could you explain my how you connect your CT clamps in your case and if it works well now ?
Thanks !
