I did follow your advice and uncommented the unsupported tag in the zwave cache file in HA. Unfortunately it still doesn’t trigger some useful information for use in an automation. This is the output:
2018-12-14 21:37:21.060 Info, Raw: 0x98, 0x81, 0x07, 0x4b, 0x53, 0x48, 0xc5, 0x2a, 0xf6, 0x14, 0x57, 0x41, 0x94, 0xc3, 0xc4, 0x87, 0xe9, 0x53, 0x1a, 0x18, 0x88, 0x7e, 0x6b, 0x9e, 0xe6, 0xed, 0x21, 0x82, 0x95
2018-12-14 21:37:21.060 Detail, Node002, Decrypted Packet: 0x00, 0x70, 0x06, 0x09, 0x04, 0x02, 0x00, 0xc7, 0x1c
2018-12-14 21:37:21.061 Detail, Node002, Refreshed Value: old value=33599258, new value=33605404, type=int
2018-12-14 21:37:21.061 Detail, Node002, Changes to this value are not verified
2018-12-14 21:37:21.061 Info, Node002, Received Configuration report: Parameter=9, Value=33605404
2018-12-14 21:37:21.061 Detail, Node002, Notification: ValueChanged
2018-12-14 21:37:21.460 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x98, 0x40, 0x2b
2018-12-14 21:37:21.461 Info, Node002, Received SecurityCmd_NonceGet from node 2
2018-12-14 21:37:21.461 Info, NONCES: 0xb7, 0xe2, 0xbe, 0x3b, 0x5c, 0xe3, 0xfa, 0x3f
2018-12-14 21:37:21.461 Info, NONCES: 0x18, 0x33, 0x62, 0x7e, 0x1a, 0xcd, 0x8a, 0x29
2018-12-14 21:37:21.461 Info, NONCES: 0xa7, 0xfe, 0xaf, 0x11, 0x6d, 0x87, 0x0a, 0x79
2018-12-14 21:37:21.461 Info, NONCES: 0xff, 0x4d, 0xb7, 0xdc, 0x5a, 0x91, 0x06, 0x75
2018-12-14 21:37:21.461 Info, NONCES: 0xe3, 0x03, 0xf4, 0x2a, 0x89, 0x4d, 0x97, 0x8b
2018-12-14 21:37:21.461 Info, NONCES: 0x33, 0xaf, 0xe8, 0xbc, 0xfc, 0x80, 0x48, 0xd6
2018-12-14 21:37:21.461 Info, NONCES: 0x9e, 0x9d, 0x07, 0x0f, 0x65, 0xb5, 0xa4, 0x89
2018-12-14 21:37:21.461 Info, NONCES: 0x0c, 0xdd, 0xee, 0x04, 0xda, 0xf2, 0xff, 0xdb
2018-12-14 21:37:21.461 Info, Node002, Sending (WakeUp) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x02, 0x0a, 0x98, 0x80, 0xa7, 0xfe, 0xaf, 0x11, 0x6d, 0x87, 0x0a, 0x79, 0x05, 0x01, 0x97:
2018-12-14 21:37:21.469 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-14 21:37:21.469 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-14 21:37:21.487 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2018-12-14 21:37:21.487 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-12-14 21:37:21.507 Detail, Node002, Received: 0x01, 0x22, 0x00, 0x04, 0x00, 0x02, 0x1c, 0x98, 0x81, 0xf4, 0xa1, 0x7e, 0xdd, 0xc7, 0x20, 0x87, 0x59, 0x49, 0x9d, 0xa0, 0xc6, 0x72, 0xb0, 0x33, 0xda, 0xd8, 0xa7, 0xb7, 0x9e, 0x4d, 0xa6, 0x47, 0x05, 0x7e, 0x3a, 0x33
2018-12-14 21:37:21.507 Info, Raw: 0x98, 0x81, 0xf4, 0xa1, 0x7e, 0xdd, 0xc7, 0x20, 0x87, 0x59, 0x49, 0x9d, 0xa0, 0xc6, 0x72, 0xb0, 0x33, 0xda, 0xd8, 0xa7, 0xb7, 0x9e, 0x4d, 0xa6, 0x47, 0x05, 0x7e, 0x3a, 0x33
2018-12-14 21:37:21.507 Detail, Node002, Decrypted Packet: 0x00, 0x70, 0x06, 0x0a, 0x04, 0x02, 0x00, 0x70, 0x1d
2018-12-14 21:37:21.507 Detail, Node002, Refreshed Value: old value=33588507, new value=33583133, type=int
2018-12-14 21:37:21.508 Detail, Node002, Changes to this value are not verified
2018-12-14 21:37:21.508 Info, Node002, Received Configuration report: Parameter=10, Value=33583133
2018-12-14 21:37:21.508 Detail, Node002, Notification: ValueChanged
The values are in Parameter 9 and 10 and I don’t know how to use the information in an automation.
I will try the support forum on google.
Thanks!
