I am trying to use the variables: statement in an automation wo define some variables to be used in actions.
This template block is meant to make sure that if I have an eco_off time of e.g. 7 am and eco_on after midnight, then I can still compare now() with both the input_datetime times. Maybe there is a much better way of doing it…
For some reason my script gets the error:
Logger: homeassistant.config
Source: config.py:424
First occurred: 22:52:48 (22 occurrences)
Last logged: 23:05:47
Invalid config for [automation]: Expected a dictionary @ data['condition'][1]['conditions'][0]. Got None expected a dictionary for dictionary value @ data['variables']. Got None. (See /config/configuration.yaml, line 8).
Invalid config for [automation]: expected a dictionary for dictionary value @ data['variables']. Got None. (See /config/configuration.yaml, line 8).
I think it’s coming from the multiline template defining the variable on_ts. If it’s indentation, then I have no idea how indentation in multiline templates is supposed to work. Maybe it’s a question of scope? Can I use variable defined in the same variables: block if they are defined on a line before?
I’ve tried redefining off_ts inside the template with temp_ts, and even naming it something else, but this didn’t help.
Any help appreciated:
- id: auto_heating_eco_off_back
alias: "Heating: ECO off when someone comes back"
description: Leave ECO mode heating if someone comes back
- platform: state
entity_id: group.inhabitants
to: 'on'
# Define times in terms of integers of timestamps. Take into account adjustemnt of on time is after midnight
variables:
now_ts: "{{ as_timestamp(now()) | int }}"
off_ts: "{{as_timestamp( now().strftime('%Y-%m-%d ') + states('input_datetime.heating_eco_off')[0:5] ) | int}}"
on_ts: >
{% set temp_ts = as_timestamp( now().strftime('%Y-%m-%d') +' '+ states('input_datetime.heating_eco_on')[0:5] ) | int %}
{% if temp_ts<= off_ts %} {% set temp_ts = temp_ts + 86400 %} {% endif %}
{{temp_ts}}
off_holiday_ts: "{{as_timestamp( now().strftime('%Y-%m-%d') +' '+ states('input_datetime.heating_eco_off_holiday')[0:5] ) | int}}"
on_holiday_tomorrow_ts: >
{% set temp_ts = as_timestamp( now().strftime('%Y-%m-%d') +' '+ states('input_datetime.heating_eco_on_holiday_tomorrow')[0:5] ) | int %}
{{temp_ts}}
condition:
- condition: state
entity_id: input_boolean.heating_season
state: "on"
- condition: or
conditions:
- "{{ is_state('binary_sensor.workday', 'on') and (now_ts >= off_ts }}"
- "{{ is_state('binary_sensor.workday', 'off') and (now_ts >= off_holiday_ts) }}"
- condition: or
conditions:
- "{{ is_state('binary_sensor.workday_tomorrow', 'on') and (now_ts < on_ts) }}"
- "{{ is_state('binary_sensor.workday_tomorrow', 'off') and (now_ts < on_holiday_tomorrow_ts)}}"
- service: climate.set_preset_mode
entity_id:
- climate.trv_salon
- climate.trv_master
- climate.trv_bath
preset_mode: none
- service: notify.persistent_notification
title: "ECO off: someone back"
message: "Indeed"
mode: restart
