Hi all,
Noob here.
I have this:
automation:
- alias: Sync Heating Status from Zipato
platform: state
entity_id: binary_sensor.HeatStatus
- condition: state
state: 'on'
- service: switch.turn_on
entity_id: switch.zipato_sensor
#off
- condition: state
state: 'off'
- service: switch.turn_ff
An attempt at 2 actions with it’s own condition each. Independently, these definitely work. But when combined like above, only the first action works.
Is my syntax wrong? Is the above possible or do I have to break it out into two triggers - one for “on” and one for “off”?
Thanks.
If your first condition is not fulfilled the first action is not triggered and the second condition is not evaluated because the sequence has not made it beyond the first condition.
I see two options:
- Wrap your conditons/actions into an if-then-else
- Use a template template to evaluate what the trigger was and adjust the action accordingly.
Both will work only after you corrected turn_ff to turn_off, of course.
Here is an example of how to evaluate triggers and adjust the action accordingly:
- alias: XMas Lights Mirror
# initial_state: "off"
- platform: state
entity_id: switch.sonoff_s31_01, switch.sonoff_s31_02
to: 'off'
- platform: state
to: 'on'
service_template: >
{% if trigger.to_state.state == "on" %}
switch.turn_on
{% elif trigger.to_state.state == "off" %}
switch.turn_off
{% endif %}
data_template:
entity_id: >
{% if trigger.from_state.entity_id == "switch.sonoff_s31_01" %}
{% elif trigger.from_state.entity_id == "switch.sonoff_s31_02" %}
{% endif %}
Because you only using one switch as trigger and action you can lose a lot of code, obviously, e.g. the whole entity_id thing.
I’m getting:
Error loading /home/homeassistant/.homeassistant/configuration.yaml: while scanning for the next token
found character ‘%’ that cannot start any token
in “/home/homeassistant/.homeassistant/configuration.yaml”, line 205, column 8
For this:
automation:
platform: state
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
Line 205 is the “if trigger.to_state.state == on” line.
Try and indent the text under service_template by 2 spaces and the entity_id by 1:
automation:
platform: state
service_template: >
switch.turn_on
switch.turn_off
{% endif %}
that was it. thank you.
side question while I have you: can one use a data template for the initial value of sensors?
Can you please elaborate, what do you mean with ‘initial value’?
Got an example?
