I´m using an NodeMCU with 4 SDA1115 attached.
All 4 are working (tested wir Tasmota-firmware).
With ESPHome I´m only able to get information of one ADS115 with its 4 channels,
because I don´t know how to build the correct configuration.
Can anyone please help me to get the other three ADS1115 to work?
Kind regards
Frank
My configuration file is:
i2c:
sda: D2
scl: D1
scan: True
ads1115:
i2c_id: bus_a
address: 0x48
# continuous_mode: on
# ads1115-48
- name: "ADS1115 48 Channel A0-GND"
ads1115_id: ads1115_48
multiplexer: 'A0_GND'
gain: 6.144
platform: ads1115
- name: "ADS1115 48 Channel A1-GND"
multiplexer: 'A1_GND'
gain: 6.144
platform: ads1115
- name: "ADS1115 48 Channel A2-GND"
multiplexer: 'A2_GND'
gain: 6.144
platform: ads1115
- name: "ADS1115 48 Channel A3-GND"
multiplexer: 'A3_GND'
gain: 6.144
platform: ads1115
I have the same problem, is there a solution?
Hi Patrick,
as a got no answer here, I decided to try get a solution by myself.
Here is my working configuration as an example
You have to complete missing items
Notice to connect the adresses of each ads-hardware as discribed in the manufacture guide
ESPHome-Config:
# example ads1115
ads1115:
# continuous_mode : on
- address: 0x48
- address: 0x49
- address: 0x4A
# - address: 0x4B
# id: ads1115_4B
# ads1115-48
- name: "Akku 01"
gain: 6.144
platform: ads1115
unit_of_measurement: "V"
icon: "mdi:gauge"
accuracy_decimals: 2
filters:
- calibrate_linear:
- 0.129 -> 0.000
- 0.132 -> 0.001
- 0.135 -> 0.002
- 3.051 -> 34.54
# - 0.64200 -> 9.968
# - 0.96600 -> 14.941
# - 1.29000 -> 20.019
# - 1.61700 -> 25.03
# - 1.95900 -> 30.36
# filters:
# - calibrate_polynomial:
# degree: 2
# datapoints:
# # Map 0.0 (from sensor) to 0.0 (true value)
# - 0.0 -> 0.0
# - 0.129 -> 0.0
# - 3.051 -> 34.54
- name: "Akku 02"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.132 -> 0.000
- 3.132 -> 34.57
- name: "Akku 03"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.129 -> 0.000
- 3.051 -> 34.59
- name: "Akku 04"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.132 -> 0.000
- 3.060 -> 34.55
# ads1115-49
- name: "Akku 05"
ads1115_id: ads1115_49
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.132 -> 0.000
- 3.093 -> 34.54
- name: "Akku 06"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.129 -> 0.000
- 2.994 -> 34.60
- name: "Akku 07"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.132-> 0.000
- 3.111 -> 34.59
- name: "Akku 08"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.138 -> 0.000
- 3.153 -> 34.57
# ads1115-4A
- name: "Akku 09"
ads1115_id: ads1115_4A
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.132 -> 0.000
- 3.096 -> 34.54
- name: "Akku 10"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.132 -> 0.000
- 3.021 -> 34.55
- name: "Akku 11"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 0.135 -> 0.000
- 3.132 -> 34.56
- name: "Powerwall Strom"
gain: 6.144
platform: ads1115
icon: "mdi:gauge"
filters:
- calibrate_linear:
- 1.038 -> 10.06
- 1.659 -> 0.00
# ads1115-4B
# - name: "Powerwall Strom"
# id: ads1115_4B_a0
# ads1115_id: ads1115_4B
# multiplexer: 'A0_GND'
# gain: 6.144
# platform: ads1115
# unit_of_measurement: "V"
# icon: "mdi:gauge"
# accuracy_decimals: 2
# - name: "Reserve 01"
# id: ads1115_4B_a1
# multiplexer: 'A1_GND'
# gain: 6.144
# platform: ads1115
# icon: "mdi:gauge"
# - name: "Reserve 02"
# id: ads1115_4B_a2
# multiplexer: 'A2_GND'
# gain: 6.144
# platform: ads1115
# icon: "mdi:gauge"
# - name: "Reserve 03"
# id: ads1115_4B_a3
# multiplexer: 'A3_GND'
# gain: 6.144
# platform: ads1115
# icon: "mdi:gauge"
1800Power:
Thanks for this. Worked perfectly for me once I got through the trials of getting a Wemos D1 Mini Pro to flash with ESPHome. I never have problems with nodemcu’s but I needed the external antenna for this job.
gurues
(gurues)
January 15, 2022, 2:05am
6
Thanks for sharing. works perfectly with wemos d1 mini and 2 ADS1115.
