Multiple Amcrest Cameras
I have two Amcrest cameras that I would like to see a live feed of in HA
I have my configuration setup as below
amcrest:
  - host: "192.168.1.111"
    username: XXXXXX
    password: XXXXXX
    port: "8085"
  - host: "192.168.1.110"
    username: XXXXXX
    password: XXXXXX
    port: "8080"
When I have both, I get errors, but when I have only one camera in the configuration file, it works fine. What am I doing wrong?
Not sure why, but without changing anything it all suddenly started working with two cameras, just how I have it posted in the script above…
So I got the cameras to come up in the Dashbaord, however the response time is terrible, like over a minute if something passes in front of the camera until it shows up on the phone…this is on my home wifi network.
Is this normal? In other apps on my phone any movement is instantaneous…
Yes it is :cry:
Why is it so much slower than a normal app? There can’t be that much processing to do vs a live stream…
Mine aren’t 1 min. More like 30sec compared to 1-3aec from camera web view
Not sure why
Take a look at this
Thanks, that was very helpful. Did not even think about all of the other integration options. I used the ONVIR and got it down to like 8 seconds for a reaction.
I’m sure there are so many more things I could do with HA, but I don’t even know what those are…
Also, if you have cameras you must look at Frigate
I tried Ubiquiti, motioneye, zoneminder, blueiris, shinobi and anything else you may consider. Frigate is easy to use and provides great review capabilities
I second taking a look at Frigate, however I caution that “easy to use” may not be the case for all users as much of the configuration is manually entered in YAML and the documentation and example configurations posted by some users may not be up to date with the most recent version. It may take a bit more effort to get started, however once you get the basics, getting good results is easier than some other apps. I’ve been able to get much better motion detection results from Frigate than the other apps I tried.
