I’ve three APs at home all connected to the same router/network and all with same SSID so devices can change accordingly. I’ve noted that my Esp32 running ESPhome always connects to the same AP, which is the most distant, even loosing connection. Does it store any sort of MAC address or something that prevents the device from changing the AP it is connected automatically? Can I force it to connect to a specific AP?
I’ve tried the BSSID option and I found the problem, the device does not even connect to wifi now. It’s really strange as both APs have the same settings.
Settings are applied on the network to all APs so I assume that if one is working the other should also be.
Also that shouldn’t prevent me to ping the device directly to its IP, right?
