Multiple August locks
Hi All,
First time user, first time poster. Has anyone configured to August locks in Hassio?
I called August and they said the bridge would not work with 2. I currently have 1 configured in Hassio. It’s a 2nd gen model. Not Zwave compatible. I was thinking I could get a pro lock and use zwave compatibility to connect it direectly to Hassio.
Any thoughts?
any followup on this?
Nope. Guess no one has an answer to this.
I got two locks visible as zwave locks. but the problem that popped up with 0.73 and later is getting in my way of moving forward.
I have a gen 2 lock I was bringing it and my August doorbell into HA and then to Apple Home via the HomeKit component. I had them working fairly well until the last week or so. I keep getting a config error on my August component and haven’t figured out why yet. I can’t see either in HA right now.
Hi all,
I wanted to revisit this. I have 2 August locks. 1 - 3rd Gen (non Zwave) and 1 - 2nd Gen (non Zwave).
They are both setup in August App. When I only had the one lock, it showed up in HA. When i added the second lock to the August app, HA will no longer see any of them.
Its almost like HA doesnt know what to do when 2 locks are present.
Has anyone added 2 (non Zwave) August locks to HA?
I have 3 august locks. Two of them work with zwave. I added the august component as follows.
august:
  login_method: phone
  username: "+19998887777"
  password: <my secret password>
I restarted HA and HA recognized them just fine. The only problem is this goes out to the cloud and back to turn the locks on/off so there is a bit of a delay over what zwave would have done. You do have to have the little august hub for each device though.
Thank you. I have mine setup the same way.
The difference is, neither of the 2 locks are Zwave so they both go through the August Connect. When I only have 1 lock setup in the august app, it shows in HA. As soon as I add the second lock to the August app, neither of the locks show up in HA.
I think HA just doesn’t know what to do when it’s presented with 2 locks through the August connect. Think I might have to go the Zwave route. Unfortunately they don’t make the oval shaped locks with Zwave. I have a couple doors that only those will fit on.
Are you saying you have 3 hubs, one for each august device?
