I have a number of automations to control the outdoor lights at the front of my house:
When my device tracker is getting close to home - turn on the lights, then off again after 20mins
When I open the garage door (i.e. from inside the house) - turn on the lights, then off again after 20mins
When the doorbell rings - turn on the lights then off again after 20mins.
If motion is detected - turn on the lights then off again.
As you see, quite a bit of repitition.
What are everyone’s rule of thumb for managing these multiple automations? Do you configure each in a discrete automation? Or do you bundle them into one, with multiple triggers? How do you prevent one automation from trampling on the other, if they are separate?
