Multiple binary sensors in rf bridge
Hi all,
I am struggling adding an if statement in my yaml code.
In my house I have 6 433mhz door sensors (only open) which I connect with the sonoff rf bridge flashed with ESPhome. Now with 1 binary sensor there is no problem, but I can’t seem to integrate all six. Some help would be greatly appriciated. Here is my yaml code, where I want to make ‘Schuifpui’ work:
rf_bridge:
  on_code_received:
    then:
      - homeassistant.event:
          event: esphome.rf_code_received
            sync: !lambda 'char buffer [10];return itoa(data.sync,buffer,16);'
            low: !lambda 'char buffer [10];return itoa(data.low,buffer,16);'
            high: !lambda 'char buffer [10];return itoa(data.high,buffer,16);'
            code: !lambda 'char buffer [10];return itoa(data.code,buffer,16);'
      - if:
          condition:
            lambda: |-
              return data.code == 0xXXXXX;
          then:
            - binary_sensor.template.publish:
                state: ON
            - delay: 5s
                state: OFF
binary_sensor:
  device_class: door
  device_class: door
