Multiple cast devices - differentiatiate?
So if you have more than 1 cast device, how do you tell which is which?
The docs say:
cast:
media_player:
  • host: 192.168.1.10
there is no naming section and you cannot use the ‘integrate’ menu in the GUI - says only need to integrate 1 device.
Have you restarted with this config in place yet by chance? I’m thinking it may pull the name once connected to the cast device. I didn’t manually setup my devices, but the names were all pulled automagically.
Having problems with Discovery - it won’t turn off, so getting all my son’s devices on the network as well … got 8 cast devices, using ignore in discovery has no effect (have created an issue).
So, looking for a way to define the cast devices in configuration.yaml
you name them in customize.yaml
media_player.such_and_such:
  friendly_name: Such and Some
You name them in your Google app, so if you have Kitchen, Lounge and Bedroom in the Google app, you get media_player.kitchen, media_player.lounge and media_player.bedroom in homeassistant.
Then you just put cast: in your config, and confirm the integration from the dashboard.
thanks - will have a go with that
Edit
Great - that worked!
Pity the documents aren’t that good
