I’am working python statemachine with multiple classes in a single file.
Is this possible?
How should ik configure the apps.yaml file with multiple classes?
Any help would be great,
Thx,
Will
Is this possible?
Thx,
Will
Yes, I do it now.
Simply name the module, then the class you want to use in that file.
TBH, I don’t understand why you need to ask the question, the documentation seems quite clear. Are you having a problem with it somewhere?
Hi gpbenton,
Thanks for the answer, but I’m not sure if i need to add multiple classes:
Example:
test:
module: statemachine
class: state,base
or split it
test1
class: state
test2
class: base
Each section in the apps.yaml defines one app (an instance of the class in the definition). So the second version is what you need (and what I have).
