Djiest
1
Probably a noob question, but I can not find the answer. Can I use multiple commands in a script e.g. to switch a tv
discovery:
sequence:
service: remote.send_command
entity_id: remote.remote
command: "15"
device: "DVR KPN"
does not switch to channel 15, nothing happens
command: "1"
does switch to channel 1
Djiest
2
To answer my own question, this is the correct syntax
discovery:
sequence:
command:
- 1
- 5
device: "DVR KPN"
I distilled this information from this issue Remote send command field is only one line · Issue #10150 · home-assistant/frontend · GitHub
