Hass version 0.77.1
I have some problem in logger, history/recorder, login errors:
In logger i’ve made some exclusion (urllib3 for mjpeg cameras and others):
logger:
default: info
logs:
urllib3.connectionpool: fatal
requests.packages.urllib3.connectionpool: fatal
homeassistant.components.binary_sensor.ping: warning
homeassistant.components.switch.command_line: warning
but all error message keeps showing in the log
second problem is about history/recorder, also with base config history does not record changes
history:
recorder:
on entity graph and history graph there aren’t status changes, example:
mine external lights turn on and off correctly by automation but there is no trace in history, watching graph ligths were always off.
third problem is about login warning message, I continuosly receive warning for failed login attempt from 127.0.0.1
