@123,
thanks for your fast reply. Yes I did, but with purpose. The MQTT integration wasn’t working (still not 100%). (Could not integrate my Xiaomi Cube)
Do you think I’ll crash my instance if I decommend the other instances? I’m afraid of any dependencies.
Then it explains why you have other instances of configuration.yaml. They are part of other installations of zigbee2mqtt/Home Assistant. So now you know why you have more than two instances of configuration.yaml.
I can’t tell you what is safe to remove because I don’t know which instances of Home Assistant and zigbee2mqtt you are currently using and which ones you are not.
Careful with that advice. Docker based installs just show the mapped folder in the container (/config) which is not the actual path on the host machine.
5/ is the path used by home assistant supervised on the host file system
4/ is the path used by home assistant supervised zigbee2mqtt add-on on the host system
2/ is the path used by a manual install of zigbee2mqtt following the correct install instructions on zigbee2mqtt.io
5/ 4/ 2/ i’m pretty sure
3/ might be a configuration.yaml from a home assistant install in a venv
Configugartion.yaml-Topic mf_social, exactly this is the Problem, I ran Hassio on Docker and thats why I’ve no Idea where the “/config”-File mentoined in the “UI: Developer Tools -> Info” is. There were an old Hassio-Docker-Environment which I deinstalled due to the missing Supervisor.
So should I continue my work in [5] usr/share/hassio/homeassistant/
and rename/delete the other installed?
Zigbee-Topic
Same Problem, the old zigbee2mqtt-edge wasn’t working, so i tried the manual instruction. Than it was advised to use the Git-Hub Module from DanielWelch. So now I’ve two zigbee-confs and I don’t know which one I should work in. (Connected devices are shown in the Zigbee-Add-On-Log but not in the Developertools->States or in the Integrations)
So do you recommend to work in [4] usr/share/hassio/share/homeassistant/ and rename/delete the other ones?
1/ I really have no idea.
Hallo, so I tried finally all config-files. It seems that you have to configure multiple configs due to Docker:
#3 is important for Docker: espacelly for the “http” block in ./root/home-assistant/configuration.yaml #5 is important for all other configurations like mqtt or sigbee settings: ./usr/share/hassio/homeassistant/configuration.yaml
The rest is waste (esp. the files in the PATH_TO_YOUR_CONFIG).
I’m still not satisfied with this solution but it works somehow.
But Python Scripts according to the discription is not working. If I run “python_script.hello_world” with the params “you: name” in the service I get an error that the service has not been not found. The files are all executable with the user “root” so I assume that the folder “python_scripts” is in the wrong config-folder. Am I right with my assumption? Could you help me please to find the right “config”-folder in Docker?
