I currently have many dashboards and create using web UI from HA. Is there an easy way to backup just the dashboard or I need to manually backup one by one? Thanks
My UI isn’t nearly as extensive as yours (just 3 files). I use the file editor and copy and paste the file contents into backup files when I make significant changes. In your case, you might find using Samba or FTP and copying the files you need or even your whole lovelace directory more to your liking.
thanks bro… yes, I found it inside the .storage.
