Multiple data disks detected after upgrade to latest Home Assistant OS
Hi! Installed the latest home assistant operating system. Now getting these errors:
2 repairs
1 hour ago Unsupported system - OS-Agent issues
1 hour ago Multiple data disks detected
2 updates
Home Assistant Core
Home Assistant Core 2024_5.2
Have already tried rolling back to a full backup and it’s not helping.
If I click on the “Multiple data disks detected” I get:
Home Assistant Supervisor
At ,'dev/sda8 , we detected another active data disk (containing a file system
hassos-data from another Home Assistant installation).
You need to decide what to do with it. Otherwise Home Assistant might choose the
wrong data disk at system reboot.
If you dont want to use this data disk, unplug it from your system. If you leave it
plugged in, choose one of the following options:
Use the detected data disk instead of the current system
Mark as inactive data disk (rename file system)
I have the same issue. Not sure about the best course of action.
I just had the same, after I clicked repair my HA crashed…
It was not after an update though, I am running the latest May release for a couple of days now.
After a hard restart everything is up again. The time this happened coincides with some update on my Unify Dream Machine (Network APP). Should be unrelated, the only thing that happened during that update is temp internet loss).
Me too. Several times. Hard reboot (raspberry p4) fixes it for a few days
having same issues on RPi4, was there any resolution to this?
Bumping this - I have just started having this issue in the last 3-4 days. Home Assistant basically stops and the only thing I can do is pull the power on the RPI.
I just developed the same problem after an eeprom update and clone of the sd card ( I probably buggered the clone and had to reload the HA core from the Rpi imager…
I am running as the sd card as the system disk and have an nvme as the data disk.
How can I tell which is the desired data disk?
Which option do I choose?
Thanks!
I am a little late to the party, but was this ever solved? I just started having this EXACT same issue yesterday after upgrading to 2025.8.0
