I’ve set up the following flow to monitor my central heating kitchen zone and trigger another flow to heat it if it is below a certain temperature. It’s a bit rudimentary but it works. This afternoon I’ve noticed that for one flow of information from the 5 minute repeating delay to the retrieval of the climate sensor temperature I’m seeing loads of identical debug messages. I cannot work out why.
Can anyone spot anything obvious and help me out at all please?
Many thanks,
Matt
The flow looks like this:
And an export of it is below.
"id": "c6eb1ed7.413fd",
"type": "tab",
"label": "Monitor Kitchen",
"disabled": false,
"info": ""
"id": "22e2990.e4ca368",
"type": "server-state-changed",
"z": "c6eb1ed7.413fd",
"name": "monitor kitchen switch on?",
"server": "9133f0de.c8669",
"version": 1,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "input_boolean.monitor_kitchen",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": false,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"x": 170,
"y": 160,
"wires": [
"3c65b7f2.055fd8"
"id": "3c65b7f2.055fd8",
"type": "api-render-template",
"name": "kitchen temp",
"template": "{{state_attr('climate.kitchen', 'status').temperature}}",
"resultsLocation": "payload",
"resultsLocationType": "msg",
"templateLocation": "",
"templateLocationType": "none",
"x": 450,
"y": 200,
"wires": [
"19c0bc4f.fcb974",
"e9160b99.7d0fd8"
"id": "19c0bc4f.fcb974",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"statusType": "auto",
"x": 650,
"y": 160,
"wires": []
"id": "e9160b99.7d0fd8",
"type": "switch",
"name": "temp <= 16.5?",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "lte",
"v": "16.5",
"vt": "str"
"t": "gt",
"v": "15.5",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 660,
"y": 240,
"wires": [
"94f880c8.c7a61"
"4ff5e6a6.3755c8"
"id": "94f880c8.c7a61",
"type": "api-current-state",
"name": "if kitchen heat is on",
"version": 1,
"outputs": 2,
"halt_if": "on",
"override_topic": false,
"entity_id": "input_boolean.kitchen_heat",
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"blockInputOverrides": false,
"x": 870,
"y": 220,
"wires": [
"56ed8f1.fb6c07",
"4ff5e6a6.3755c8"
"18589514.84b32b"
"id": "56ed8f1.fb6c07",
"type": "debug",
"name": "kitchen heat already on",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1130,
"y": 180,
"wires": []
"id": "18589514.84b32b",
"type": "api-call-service",
"name": "Call kitchen Heat flow",
"version": 1,
"debugenabled": false,
"service_domain": "homeassistant",
"service": "turn_on",
"entityId": "input_boolean.kitchen_heat",
"data": "",
"dataType": "jsonata",
"mergecontext": "",
"output_location": "",
"output_location_type": "none",
"mustacheAltTags": false,
"x": 1120,
"y": 260,
"wires": [
"4ff5e6a6.3755c8"
"id": "4ff5e6a6.3755c8",
"type": "delay",
"name": "check again in 5 mins",
"pauseType": "delay",
"timeout": "5",
"timeoutUnits": "minutes",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 940,
"y": 360,
"wires": [
"706f5850.139118"
"id": "706f5850.139118",
"name": "on?",
"version": 1,
"outputs": 2,
"halt_if": "on",
"entity_id": "input_boolean.monitor_kitchen",
"state_location": "",
"override_payload": "none",
"entity_location": "",
"override_data": "none",
"x": 630,
"y": 480,
"wires": [
"3c65b7f2.055fd8"
"id": "9133f0de.c8669",
"type": "server",
"name": "Home Assistant"
