I’ve been having an odd daily issue. At random times I will have a bunch of entities go unavailable. Some of the entities:
- Battery sensor for my wall tablet via MQTT
- Chromecast devices connected to WiFi
- Light switches and plugs that run Tasmota
- Lutron bridge connected via Wifi.
There doesn’t seem to be any single variable pointing me to the problem. Here are my logs. I noticed the issue at 10:51
A reboot solves the issue.
Any ideas what is causing this?
2021-06-04 10:50:05 WARNING (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 172.30.33.7, but your HTTP integration is not set-up for reverse proxies; This request will be blocked in Home Assistant 2021.7 unless you configure your HTTP integration to allow this header 2021-06-04 10:50:05 ERROR (MainThread) [homeassistant.components.mobile_app.webhook] Refusing to update homeassistant's SM-G975U non-registered sensor: 6eba9733fea85ca2c43ff3a4f0d3dc3c75f69566f8718075d402555bd0f01db4_next_alarm 2021-06-04 10:51:51 WARNING (Thread-8) [pychromecast.socket_client] [Nursery speaker(192.168.1.23):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:51 WARNING (Thread-17) [pychromecast.socket_client] [Basement TV(192.168.1.244):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:51 WARNING (Thread-12) [pychromecast.socket_client] [Upstairs Speakers(192.168.1.25):32154] Heartbeat timeout, resetting connection 2021-06-04 10:51:52 WARNING (MainThread) [homeassistant.components.denonavr.media_player] Timeout connecting to Denon AVR receiver at host 192.168.1.179. Device is unavailable 2021-06-04 10:51:53 ERROR (SyncWorker_27) [homeassistant.components.life360.device_tracker] get_circles: CommError: HTTPSConnectionPool(host='api.life360.com', port=443): Max retries exceeded with url: /v3/circles.json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xa2fe1f40>: Failed to establish a new connection: [Errno -3] Try again')) 2021-06-04 10:51:55 WARNING (Thread-15) [pychromecast.socket_client] [Living Room TV(192.168.1.242):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:55 WARNING (Thread-19) [pychromecast.socket_client] [All Speakers(192.168.1.20):32223] Heartbeat timeout, resetting connection 2021-06-04 10:51:55 WARNING (Thread-20) [pychromecast.socket_client] [Basement speaker(192.168.1.20):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-11) [pychromecast.socket_client] [Main Floor(192.168.1.24):32208] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-13) [pychromecast.socket_client] [Living room and kitchen(192.168.1.24):32201] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-16) [pychromecast.socket_client] [Whole house(192.168.1.24):32037] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-18) [pychromecast.socket_client] [Kitchen display(192.168.1.24):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-10) [pychromecast.socket_client] [Master Bedroom speaker(192.168.1.25):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-9) [pychromecast.socket_client] [Beyer's Room speaker(192.168.1.245):8009] Heartbeat timeout, resetting connection 2021-06-04 10:51:56 WARNING (Thread-14) [pychromecast.socket_client] [Living Room speaker(192.168.1.237):8009] Heartbeat timeout, resetting connection 2021-06-04 10:52:01 ERROR (Thread-13) [pychromecast.socket_client] [Living room and kitchen([::ffff:c0a8:118]):32201] Failed to connect to service ServiceInfo(type='host', data=('[::ffff:c0a8:118]', 32201)), retrying in 5.0s 2021-06-04 10:52:01 ERROR (SyncWorker_6) [homeassistant.components.life360.device_tracker] Suppressing further errors until OK: get_circles: CommError: HTTPSConnectionPool(host='api.life360.com', port=443): Max retries exceeded with url: /v3/circles.json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xa2d1ecd0>: Failed to establish a new connection: [Errno -3] Try again')) 2021-06-04 10:52:04 ERROR (MainThread) [homeassistant.components.brother] Error fetching brother data: No SNMP response received before timeout 2021-06-04 10:52:13 WARNING (MainThread) [hass_nabucasa.google_report_state] Unable to connect: Cannot connect to host remotestate.nabucasa.com:443 ssl:default [Try again] 2021-06-04 10:52:14 WARNING (MainThread) [pylutron_caseta.smartbridge] ping was not answered. closing connection. 2021-06-04 10:52:17 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for kass_noise_sensor (192.168.1.32): Timeout while connecting to ('192.168.1.32', 6053) 2021-06-04 10:52:21 ERROR (Thread-8) [pychromecast.socket_client] [Nursery speaker(192.168.1.23):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Home-Mini-d76804d4808009462d1b1806a8e38a31._googlecast._tcp.local.'), retrying in 5.0s 2021-06-04 10:52:21 ERROR (Thread-17) [pychromecast.socket_client] [Basement TV(192.168.1.244):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.244', 8009)), retrying in 5.0s 2021-06-04 10:52:21 ERROR (Thread-12) [pychromecast.socket_client] [Upstairs Speakers(192.168.1.25):32154] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.25', 32154)), retrying in 5.0s 2021-06-04 10:52:25 ERROR (Thread-15) [pychromecast.socket_client] [Living Room TV(192.168.1.242):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.242', 8009)), retrying in 5.0s 2021-06-04 10:52:25 ERROR (SyncWorker_1) [homeassistant.components.life360.device_tracker] get_circles: OK again 2021-06-04 10:52:25 ERROR (Thread-19) [pychromecast.socket_client] [All Speakers(192.168.1.20):32223] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.20', 32223)), retrying in 5.0s 2021-06-04 10:52:25 ERROR (Thread-20) [pychromecast.socket_client] [Basement speaker(192.168.1.20):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.20', 8009)), retrying in 5.0s 2021-06-04 10:52:26 ERROR (Thread-11) [pychromecast.socket_client] [Main Floor(192.168.1.24):32208] Failed to connect to service ServiceInfo(type='mdns', data='Google-Cast-Group-a69b7a49f2674462976e0bb3de34e3aa._googlecast._tcp.local.'), retrying in 5.0s 2021-06-04 10:52:26 ERROR (Thread-16) [pychromecast.socket_client] [Whole house(192.168.1.24):32037] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.24', 32037)), retrying in 5.0s 2021-06-04 10:52:26 ERROR (Thread-18) [pychromecast.socket_client] [Kitchen display(192.168.1.24):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Nest-Hub-Max-6090d21580b30f275c7ae1d2b43c6789._googlecast._tcp.local.'), retrying in 5.0s 2021-06-04 10:52:26 ERROR (Thread-10) [pychromecast.socket_client] [Master Bedroom speaker(192.168.1.25):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Home-Mini-bb4bcfd9b5561ec9c57efa31f9036c24._googlecast._tcp.local.'), retrying in 5.0s 2021-06-04 10:52:26 ERROR (Thread-9) [pychromecast.socket_client] [Beyer's Room speaker(192.168.1.245):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.245', 8009)), retrying in 5.0s 2021-06-04 10:52:26 ERROR (Thread-14) [pychromecast.socket_client] [Living Room speaker(192.168.1.237):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.1.237', 8009)), retrying in 5.0s 2021-06-04 10:52:30 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:53:01 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:53:34 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:53:56 ERROR (MainThread) [snitun.multiplexer.core] Ping fails, no response from peer 2021-06-04 10:54:08 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:54:41 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:55:14 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:55:48 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:56:21 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:56:54 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:57:27 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:58:01 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:58:34 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:59:07 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 10:59:41 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 11:00:14 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 11:00:47 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 11:01:20 WARNING (MainThread) [haffmpeg.core] FFmpeg isn't running! 2021-06-04 11:01:23 WARNING (MainThread) [pylutron_caseta.smartbridge] LEAP session ended. Reconnecting... 2021-06-04 11:01:26 WARNING (MainThread) [pylutron_caseta.smartbridge] Reconnecting... Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/pylutron_caseta/smartbridge.py", line 421, in _monitor_once self._leap = await self._connect() File "/usr/local/lib/python3.8/site-packages/pylutron_caseta/smartbridge.py", line 112, in _connect res = await open_connection( File "/usr/local/lib/python3.8/site-packages/pylutron_caseta/leap.py", line 178, in open_connection reader, writer = await asyncio.open_connection(host, port, limit=limit, **kwds) File "/usr/local/lib/python3.8/asyncio/streams.py", line 52, in open_connection transport, _ = await loop.create_connection( File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1025, in create_connection raise exceptions[0] File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1010, in create_connection sock = await self._connect_sock( File "/usr/local/lib/python3.8/asyncio/base_events.py", line 924, in _connect_sock await self.sock_connect(sock, address) File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 496, in sock_connect return await fut File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 528, in _sock_connect_cb raise OSError(err, f'Connect call failed {address}') OSError: [Errno 113] Connect call failed ('192.168.1.134', 8081)
Sorry for that. I have been running home assistant behind a reverse proxy for years. But since I migrated to docker I stopped using Nginx for home assistant (still use it for around 40 other containers). Lets say that at my age these things get fuzzy…
