In Devices, I have 4 iphones, all with the same name (my phone’s name). Two are iphone6s and two are iphone8, which has a SW version that matches my phone.
I have read several threads on this forum where people deleted from the below referenced files with no luck.
In the threads on this subject, there is a recommendation to delete the ‘ios.conf’ file; I cannot find this anywhere in my system (samba to connect to files; after showing hidden files).
Does anyone have direction on how to get rid of these entries?
I am also not certain how HASS should be set up to work with HA Cloud and the mobile app vis a vis earlier implementations of trackers and notifications, so any high level description is appreciated. I am setup on HA Cloud and on my phone app, but notifications are not working.
in core.config_entries, I can see the two iphones. the other’s app_version is 2020.4.1(1) though.
"entry_id": "some entry ID",
"version": 1,
"domain": "mobile_app",
"title": "my iPhone",
"data": {
"app_data": {
"push_token": "some token",
"push_url": "https://mobile-apps.home-assistant.io/api/sendPushNotification"
"app_id": "io.robbie.HomeAssistant",
"app_name": "Home Assistant",
"app_version": "2020.7 (11)",
"device_id": "some device ID",
in core.device_registry, I can see four iphones grouped in pairs. Each entry in a pair has identical headers and the number in the header matches the entry in the core.config_entries file. as such:
"config_entries": [
"matches core.config_entries entry_id"
"connections": [],
"identifiers": [
"mobile_app",
"matches core.config_entries device_id"
in core.entity_registry, I have 20 entries that correspond to the above.
"entity_id": "sensor.sim_1_2",
"config_entry_id": "matches core.config_entries entry_id",
"device_id": "matches number in core.device_registry "id:" ",
Both core.config_entries entries are linked to my user_id located in the PERSON file. Otherwise, I do not find iPhone anywhere else in the files.
