thats very hard to do for a custom widget that we dont know.
do you have a link to the custom widget?
did you copy the custom widget to the right place? with the right filerights?
do you get errors?
is there any kind of description?
leaving things empty after a : is most of the times a bad idea.
if its written correct then those lines are not needed.
Rene, there’s no such widget) I’m trying to make one.
Looking for some examples how I can add additional switch toggle to corner of the exist widget with additional entity_id.
it’s just an example/skeleton, of course it will come with icon/style definitions…
first you need to create a working custom widget. (for instance by copying an existing one and modifying it.)
then you can start to change it.
but you really need to know your way around in programming javascript, css and html
you can compare the base_heater with base_switch files.
base_switch has only 1 entity, base_heater has 2 entities.
the problem is that a widget like that isnt that usefull in most cases.
you need at least the space from four widgets to make it workable (or else the toucharea would be to small)
so you could also use 4 widgets to do the trick.
Useful or not it depends)
For my setup heater is absolutely useless, but I’m not stating that it isn’t useful for others)
4 widgets can work but it’s ugly, same as having 4 widgets for the heater (temperature sensor, fan, minus and plus buttons for the temperature)
In my setup I want to use for example big button (2x2) to turn on/off the tv, and the small buttons/icons in the corners will control tv input (usually no need to change, only sometimes) so it will accessible but not taking too much extra space.
i meant it isnt usefull like it wont be workable unless you set the size to 2x2
and then you can use 4 widgets which takes the same place and just configere it so that they look as 1 widget.
Still, the idea is one big “main” trigger (often use, common/standard scene) and several small (not often use, advanced entities). I started a repository, tried to put additional entity as I saw in baseheater, but no luck, the icon updating on both buttons:
by the way, the best way to learn how to create custom widgets is by following the instructions from the one who created the dashboard program.
he did a hell of a job writing instructions down.
