Multiple entities on a Custom button card
Hello, I am trying to make a simple Custom button card, but showing multiple entities:
Beze jména
It should work as follow:
  • read temperatures from a thermostat
  • a grey colored one is a target temperature
  • a black colored one is a real temperature - but if heating on changed to green
  • default background, but if the doors sensor indicates “doors open” status, changed to white
Anybody having an idea how to get two temperature figures to the Custom button card?
I was searching through many samples, but either they were not covering my need, or were too difficult for me to understand…
The vertical stack in card from HACS may help. It works like the normal vertical stack card, but hides the borders making the whole stack look like one card.
Thank you @Stiltjack, I played with the Vertical stack in card you suggested and this might be the solution. I just do not know how to remove the gap between the inserted values:
Beze jména 2
the current code is as following (still a lot of work to get it formatted according to state of sensors):
type: custom:vertical-stack-in-card
cards:
  - type: custom:button-card
    entity: sensor.teplomer_bazen_1
    show_state: true
    show_icon: false
    styles:
      card:
        - color: yellow
        - font-size: 15px
    entity: sensor.teplomer_bazen_2
    show_state: true
    show_name: false
    show_icon: false
    styles:
      card:
        - color: yellow
        - font-size: 15px
@dolezel.david,
I do not know if you ever found a solution (I was searching for one too). Let me share what I came up with to have multiple entity states in a single custom button card:
cards:
    show_state: true
    show_icon: false
    show_state: true
    state_display: |
      return 'teplomer_bazen_1: '+(states['sensor.teplomer_bazen_1'].state)+'°C'
    show_label: true
    label: |
      [[[ return 'teplomer_bazen_2: '+(states['sensor.teplomer_bazen_2'].state)+'°C']]]
    styles:
      card:
        - color: yellow
        - font-size: 15px
Note: You can also apply another state in the name field too.
      return 'teplomer_bazen_3: '+(states['sensor.teplomer_bazen_3'].state)+'°C'
And of course you can still have an icon if you wish. Full disclosure: I am not certain of the language in the post; however, anyone looking to have more than one entity state in a custom button card can use and modify any of the above reply.
@007DJ Sorry, I missed your answer - did not get any notification :frowning:
I resolved this using a similar solution:
entity: sensor.teplota_loznice_patro
show_state: true
show_icon: false
show_label: true
label: |
    return  states['sensor.teplota_loznice_patro_target'].state + " °C"
styles:
  card:
    - height: 60px
    - color: yellow
    - font-size: 15px
    - font-weight: bold
  label:
    - color: '#D0CECE'
    - font-size: 14px
  name:
    - color: yellow
    - font-size: 15px
    - font-weight: bold
  background:
    - color: red
card_mod:
  style: |
    ha-card {
      background-color: {% if is_state('switch.senz_okna_patro_lozn_468', 'on') %} #FF99FF {% elif is_state('sensor.status_termostat_loznice_patro', 'heating') %} green {% else %}  {% endif %} };
Are you able to click on the 2nd entity
