Multiple entities with numeric state triggers
Is there any way to monitor multiple entities with the numeric state trigger? I want to do something like the following:
- alias: 'Battery Low Alert'
    platform: numeric_state
    entity_id: sensor.basement_thermostat_battery, sensor.downstairs_thermostat_battery
    below: 10
    service: notify.Pushover
    data_template:
      message: >
        {{ trigger.entity_id|replace('sensor.', '')|replace('_', ' ')|capitalize }} is at {{ states(trigger.entity_id)}}%
      title: ""
With one sensor it works fine, but if I add another one it actually seems to break all of my automations.
Andrew, did you ever solve this on? I have the same Q
No - I have since moved all my automatons over to AppDaemon.
Bump. It feels like this should be possible since it works with state triggers.
I’ve solved it using the following automation, hope this will be of help :
    - platform: numeric_state
      entity_id:
      - sensor.guest_bathroom_plant_battery
      - sensor.grandpa_plant_battery
      - sensor.entrance_plant_battery
      below: 10
      for:
        hours: 1
  condition:
    condition: and
    conditions:
     - condition: time
       after: '18:00:00'
       before: '21:00:00'
     - condition: state
       entity_id: sensor.ohad_home
       state: 'true'
  - service: notify.ios_ohad_iphone
    data_template:
      message: '{{ trigger.from_state.attributes.friendly_name }} plant sensor - battery low'
        push:
          badge: 0
          category: 'plantnotification'
Tested it and seems to work welll
