I have some problems with my automation. I want so dim only lights that are on. So I try to check if the entity has the state on. But the automation didn’t work. Maybe someone can help me with this? I didn get an error, it simply doesnt work:(
- alias: 'Media Player Start'
- platform: state
entity_id: media_player.wohnzimmer
to: 'playing'
- platform: state
entity_id: media_player.ps4
to: 'playing'
- service: homeassistant.turn_on
data_template:
transition: "2"
entity_id: >
"{% if is_state('light.wohnzimmer_tv_rack', 'on') %}, light.wohnzimmer_tv_rack{% endif %}
{% if is_state('light.wohnzimmer_hifi', 'on') %}, light.wohnzimmer_hifi{% endif %}
{% if is_state('light.wohnzimmer_stehlampe_unten', 'on') %}, light.wohnzimmer_stehlampe_unten{% endif %}
{% if is_state('light.wohnzimmer_stehlampe_oben', 'on') %}, light.wohnzimmer_stehlampe_oben{% endif %}
{% if is_state('light.wohnzimmer_decke', 'on') %}, light.wohnzimmer_decke{% endif %}"
brightness_pct: '{{ states.input_number.helligkeit_wohnzimmer_media_pause.state | round() }}'
The automation didnt dimm the lights:(
Here is the log:
2019-08-13 20:43:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/core.py", line 1213, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 427, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data['entity_id']
When only one Light is on, the automation works. Maybe the entities have to appear like
this:
- entity 1
- entity 2
- entity 3
instead of entity 1, entity 2, entity 3.
Can you give me a hint how to do that @petro ?
I tried the following (turn on a few lights that are normally off in my house) :
- alias: 'list test'
platform: state
entity_id: input_boolean.toggler
to: 'on'
data_template:
entity_id: >
{% set entities = 'light.family',
'light.patio',
'light.kitchen',
'light.foyer' %}
{{ states | selectattr('entity_id','in', entities) | selectattr('state','eq','off') | map(attribute='entity_id') | join(', ') }}
I got the same failure ( … not a valid value for dictionary value @ data[‘entity_id’]).
I was doubly perplexed because I am certain I’ve used this elsewhere successfully. Then I changed:
to:
service: light.turn_on
and the automation worked.
So there must be a difference in how the two services validate their entity_id. I haven’t looked at the source code but I’m guessing homeassistant.turn_on has a more constrained interpretation of what is a valid entity_id whereas light.turn_on is more accommodating.
Another interpretation is that the validation code for homeassistant.turn_on has a bug …
That’s interesting. I’ll look into the code later for this. I’m wondering why that doesn’t work. I’d lean towards bug. But homeassistant.turn_on is more general so it’s up in the air.
