Multiple-entity-row. Use attribute as name
Hello
Really like this frontend customisation.
I’m wondering if someone could assist please. I’m trying to use an attribute as a name, specifically show time as name and value as the value. It looks like the template is getting parsed but something is not working and I don’t know what. Maybe it’s just not possible.
   - type: custom:multiple-entity-row
    entity: sensor.env_lounge_humidity_cal
    show_state: false
    entities:
      - entity: sensor.template_env_lounge_humidity_cal_min_today
        name: {{ sensor.template_env_lounge_humidity_cal_min_today', 'ts_updated') }}
Configuration errors detected:
missed comma between flow collection entries (20:82)
 17 |  ...
 18 |  ...
 19 |  ... _cal_min_today
 20 |  ... y_cal_min_today', 'ts_updated') }}
 21 |  ... _cal_max_today
 22 |  ...
Thanks in advance
name: "{{ state_attr('sensor.template_env_lounge_humidity_cal_min_today', 'ts_updated') }}"
That’s assuming the card supports templates in the name. Which it probably doesn’t.
I don’t believe name: will accept a template.
It doesn’t :grinning:
Yeah I was just looking it up:
Screenshot 2024-06-09 at 18-49-46 benct_lovelace-multiple-entity-row Show multiple entity states and attributes on entity rows in Home Assistant's Lovelace UI
So the only way to do it is with this:
It’s possible via a pseudo element and card_mod, but your suggestion is less convoluted :laughing:
Thanks everyone.
That config-template-card integration worked perfectly. Awesome.
type: custom:config-template-card
entities:
  - sensor.template_env_lounge_temperature_cal_min_today
variables:
  TS_TEMP_MIN: >-
    new Date(states['sensor.template_env_lounge_temperature_cal_min_today'].attributes.ts_updated).toLocaleTimeString().replace(/(.*)\D\d+/, '$1')
card:
  type: entities
  entities:
      entity: sensor.env_lounge_temperature_cal
      show_state: false
      entities:
        - entity: sensor.template_env_lounge_temperature_cal_min_today
