Multiple error entries in logs
Hello All,
I just installed lovelace dashboards and I noticed in my logs there are multiple error entries about cards being already installed. Could someone point me in the right direction to remove them? Thanks.
2023-02-02 02:56:31.198 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "button-card" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.200 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "light-entity-card" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.202 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "lovelace-card-mod" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.203 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "lovelace-auto-entities" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.205 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "mini-graph-card" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.207 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "mini-media-player" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.209 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "lovelace-layout-card" is already installed, Remove it or disable include custom cards
2023-02-02 02:56:31.211 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "lovelace-state-switch" is already installed, Remove it or disable include custom cards
I have the same logs and custom-cards are not working. I see A LOT of entries for every custom component. for example:
➜  ~ find /config -name "mini-media-player.js"
/config/ui_lovelace_minimalist/cards/mini-media-player/mini-media-player.js
/config/ui_lovelace_minimalist/custom_cards/mini-media-player/mini-media-player.js
/config/ui_lovelace_minimalist/__ui_minimalist__/ulm_templates/custom_cards/mini-media-player/mini-media-player.js
/config/custom_components/ui_lovelace_minimalist/cards/mini-media-player/mini-media-player.js
/config/custom_components/ui_lovelace_minimalist/__ui_minimalist__/ulm_templates/custom_cards/mini-media-player/mini-media-player.js
and if I try to use a custom-component in lovelace I get
Custom element doesn't exist: "mini-media-player"
I resolved this by removing all entries from HACS and re-adding them back.
