When I had 0.36.x I had no issues and errors. Then I upgraded to 0.37.0… There were many errors!
17-01-31 19:44:18 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform mqtt
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 164, in async_setup_platform
None, platform.setup_scanner, hass, p_config, tracker.see)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/mqtt.py", line 39, in setup_scanner
mqtt.subscribe(hass, topic, device_tracker_message_received, qos)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/event.py", line 26, in factory
hass.loop, ft.partial(async_factory, *args, **kwargs)).result()
File "/usr/lib/python3.4/concurrent/futures/_base.py", line 402, in result
return self.__get_result()
File "/usr/lib/python3.4/concurrent/futures/_base.py", line 354, in __get_result
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/util/async.py", line 167, in run_callback
future.set_result(callback(*args))
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 188, in async_subscribe
MQTT_CLIENT.subscribe(topic, qos)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 373, in subscribe
_raise_on_error(result)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/mqtt/__init__.py", line 484, in _raise_on_error
raise HomeAssistantError('Error talking to MQTT: {}'.format(result))
homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: 1
17-01-31 19:54:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 387, in _update_entity_states
yield from update_coro
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 208, in async_update_ha_state
state = self.state
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor/wunderground.py", line 164, in state
return int(self.rest.data[self._condition][:-1])
ValueError: invalid literal for int() with base 10: ''
17-01-31 19:54:57 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:55:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:55:59 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:56:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:57:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:57:32 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:58:03 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:58:34 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 19:59:05 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:04:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
yield from self.hass.loop.run_in_executor(None, self.update)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/binary_sensor/nest.py", line 101, in update
self._state = bool(getattr(self.device, self.variable))
File "/home/hass/.homeassistant/deps/nest/nest.py", line 386, in is_using_emergency_heat
return self._device.get('is_using_emergency_heat')
File "/home/hass/.homeassistant/deps/nest/nest.py", line 263, in _device
return self._devices[THERMOSTATS][self._serial]
File "/home/hass/.homeassistant/deps/nest/nest.py", line 202, in _devices
return self._nest_api._devices
File "/home/hass/.homeassistant/deps/nest/nest.py", line 1546, in _devices
return self._status[DEVICES]
File "/home/hass/.homeassistant/deps/nest/nest.py", line 1539, in _status
value = self._get("/")
File "/home/hass/.homeassistant/deps/nest/nest.py", line 1522, in _get
return self._request('GET', path)
File "/home/hass/.homeassistant/deps/nest/nest.py", line 1517, in _request
raise APIError(response)
nest.nest.APIError: service unavailable
17-01-31 20:04:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:05:17 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:05:48 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:06:19 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:06:50 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:07:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:07:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:08:23 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:08:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
17-01-31 20:09:25 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
state = self.state
