I see way too much errors at the logs.All errors are the same and the exceptions are happening nearly every second.
The Error message is this:
Wed Sep 12 2018 16:44:22 GMT+0300 (GTB Summer Time)
File “/usr/lib/python3.5/asyncio/events.py”, line 126, in _run
self._callback(*self._args)
File “/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_fileresponse.py”, line 37, in _sendfile_cb
loop.remove_writer(out_fd)
File “/usr/lib/python3.5/asyncio/selector_events.py”, line 351, in remove_writer
self._ensure_fd_no_transport(fd)
File “/usr/lib/python3.5/asyncio/selector_events.py”, line 258, in _ensure_fd_no_transport
fd, transport))
RuntimeError: File descriptor 28 is used by transport <_SelectorSocketTransport fd=28 read=polling write=<polling, bufsize=0>>
Do you use anything that communicates over the web? Like a sensor? Appears to be an issue with that. It’s possible that whatever is causing the problem doesn’t update when that error occurs.
