Multiple failures installing HA on SSD
I did the boot from USB update, got the green screen, then did the HA-RPI 64 bit load on a RPI4 (8gb). have done this 3 times and I have yet to see the home screen:
Hmm. We’re having trouble finding that site.
We can’t connect to the server at homeassistant.local.8123.
If that address is correct, here are three other things you can try:
Try again later.
Check your network connection.
If you are connected but behind a firewall, check that Firefox has permission to access the Web.
The yellow and green lights on the network connection are active, yellow is on constantly and green is constantly blinking… If I plug a monitor into the HDMI port it is sitting at ha >.
Please advise I am not sure what to try next.
Mike
I am using a Kingston 240GB A400 SSD and a StarTech USB 3.0 SATA/SSD cable with UASP.
My error now up and running, pointing to wrong IP address. Now for all the config fun.
Sorry about my error.
Mike
